Instruments and Amps Everything that makes music, Especially including instrument amps.
OC44 Yellow Jacket Pinout
Old 24th January 2013, 08:56 PM   #1
Nicho is offline Nicho  United Kingdom
Default OC44 Yellow Jacket Pinout
I have acquired what I believe to be a yellow jacket mullard oc44. which appears to has a red dot at the top but not next to a pin. It comes from a radio. The centre pin is bare wire and the two outside pins are covered with (removable) insulation; one pin has white insulation (on the side of the oc44 with a black stripe), the other has red insulation. Can anyone tell me which pin is the collector, which the emmitter, and which the base,
Chears
Nick
Old 24th January 2013, 09:15 PM   #2
or how to (safely [for the transistor]) test to determine...
Old 25th January 2013, 01:07 AM   #3
Enzo is offline Enzo  United States
Are the legs evenly spaced coming out the bottom? Or are they in an arc? Look at a more modern metal small transistor, if you look at the bottom, three legs are in a circle with a space where a fourth one would have been. Kinda like this:
http://www.rfm.com/products/case/to39-3.pdf
Old 25th January 2013, 01:30 AM   #4
Bibliophile is offline Bibliophile  Australia
OC 44, Tube OC44; Röhre OC 44 ID33607, Transistor
Old 25th January 2013, 11:11 AM   #5
Bone is offline Bone  United Kingdom
Base is normally the centre lead on all Germanium Transistors. The Collector will normally be the marked lead so that should be the one next to the stripe on the sleeve.
Old 25th January 2013, 03:06 PM   #6
Thanks for all the help. I will go for the one next to the stripe being the collector. It's separation from the center pin is also a little greater, which also fits with Bibliophile's link. One more question, how likely am I to damage it if I get it wrong and the collector up to the positive of a 9V battery?
Old 25th January 2013, 09:28 PM   #7
Well I wouldn't connect it up without testing it first. Have you a DVM with a transistor tester in it? What circuit are you using it in?
Old 25th January 2013, 10:10 PM   #8
I was going to put it in this one http://www.geofex.com/Article_Folders/ffselect.htm
Old 30th January 2013, 09:06 AM   #9
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
please let us know how it goes
Old 1st February 2013, 12:31 AM   #10
Well I appear to have killed it. The way of connecting discussed above was correct. I was getting a readout which converts to 12uA leakage (is this possible, it seems strangely low) and a hfe of 70. Then I decided to messure current through the 2.2M resistor (apparently foolish). The transistor got very hot and is now basically an open circuit between collector and emitter. Oh well. Some you lose.
OC44 Yellow Jacket PinoutHide this!Advertise here!
Teflon tubing for jacket material otto88 Parts 15 15th October 2013 02:06 AM
Woven Cloth Cable Wrap Jacket Sleeving WHATEVER YOU CALL IT jjimison Everything Else 18 3rd February 2008 06:43 AM
Jacket Heater lawbadman Everything Else 5 9th October 2005 08:31 AM
Did you know that the tightness of the jacket materials could change the sound? commstech Parts 26 14th November 2004 11:36 AM
boz in new jacket Hanzwillem Pass Labs 6 21st December 2003 09:17 PM
Copyright ©1999-2017 diyAudio
