Instruments and Amps Everything that makes music, Especially including instrument amps.
LM1876 arduino mute
LM1876 arduino mute
Old 12th January 2013, 02:50 AM   #1
dataplex is offline dataplex
Default LM1876 arduino mute
hey guys
i am waiting for my arduino MEGA to arrive in a few days.
i need to switch a bunch of LM1876's op amps on/off. they have mute pins that mute the signals passing through by receiving 2.5v.
so i figured i could use the arduino pins to switch an array of amps on/off.
however, my question is - do i need to put some kind of resistors inbetween or something to avoid drawing too much power/frying my arduino while muting 10+ LM1876's??
i should add, by default ALL AMPS WOULD BE MUTED AT THE SAME TIME - meaning id continuously be sending 5v through at least 10+ pins most of the time.
also, another question - i have never tried the LM1876's mute function - its instantaneous, right? im building a musical instrument, so if the mute function is delayed, its useless.
thanks!
Old 12th January 2013, 05:48 AM   #2
twest820 is offline twest820
You can find the mute implementation in figure 6 of the LM1876 datasheet. The pin's input impedance is not specified but should be pretty high.
Old 12th January 2013, 08:25 AM   #3
pra3718 is offline pra3718  India
Manual operated switch can be work for your specific requirement. Switch ON = 5V supply to mute pins and Switch OFF = 0V supply to mute pins and your all chips would turn in play mode.
Old 12th January 2013, 01:18 PM   #4
thanks guys,
is the mute function instantaneous? does it mute the IC right away?
thanks,
Old 12th January 2013, 02:28 PM   #5
DUG is offline DUG  Canada
Originally Posted by dataplex View Post
thanks guys,
thanks,
Some datasheets offer this information...this one does not.
You will have to test the response time and adjust your arduino accordingly.
Let us know the results.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 12th January 2013, 02:34 PM   #6
has anybody seen a schematic where the mute function is applied?
i cannot for the life of me get the damn thing to mute the signals! with a split power supply, its just 5v to pin 6 and ground, right?
thanks for all your help guys,
Old 12th January 2013, 02:52 PM   #7
tauro0221 is offline tauro0221  United States
One of the graphic in the datasheet showed the output versus the mute. Check it out.
Old 12th January 2013, 06:54 PM   #8
You can find the location of mute B in the datasheet too.
Old 12th January 2013, 06:56 PM   #9
yes, i know. i have actually been obsessively reading the datasheet for a week now. thanks though!
i think i might go for optocouplers switching the input signal on/off before the amp circuit. this just doesn't make any sense.
Old 12th January 2013, 08:11 PM   #10
You can drive directly the mute using the output from the Arduino. The mute minimum/maximum voltage it is 2 to 5 volts. I do not see any problem. If the Arduino have D/A you can send an output of 2 volts. That is the beauty of using a micro.
LM1876 arduino muteHide this!Advertise here!
cs3318 and arduino linuxworks Analog Line Level 123 27th March 2017 09:32 AM
LM1876 Mute by Voltage divider. pra3718 Chip Amps 26 9th December 2012 02:41 PM
LM1876 Mute & Stand-by pra3718 Chip Amps 14 23rd November 2012 03:59 PM
need LM1876 mute mode and standby mode help JozzaG Chip Amps 21 19th January 2012 06:28 PM
please help - no mute but did mute mod - tda1541 loomis Digital Source 1 14th November 2002 11:54 AM
Copyright ©1999-2017 diyAudio
