Instruments and Amps Everything that makes music, Especially including instrument amps.
String noise/squeek
String noise/squeek
Old 17th January 2013, 05:46 PM   #11
Robert Kesh is offline Robert Kesh  Wallis & Futuna
Robert Kesh's Avatar
Originally Posted by phase_accurate View Post
I tend to the same answers as tinitus:
Did you make a coarse check of frequency response ? Maybe some coupling C is too small or something else is giving you a insufficient low-end response.
As already mentioned the frequency response of guitar pickups is very load dependant. Electrically (i.e. without looking at things like PU position, pole size, single-coil or humbucker etc) they usually form a second order lowpass with a peak before the final drop. Your amp might be unluckily loading the PU(s) in such a way that you end up with the peak in an unpleasant frequency range.
Charles
Thanks for the response, yeah checked cap sizes coupling and cathode decoupling, and the bootstrap cap is ok (thanks to the other thread). The load on the guitar is a 1M grid leak resistor and then a 47k grid stopper to the grid itself, which is not in the least biased hot, so not leaky.
I covered 3/4 of the back of my cab and it's sounding much better, so i suspect it's cab and speaker issues.
String noise/squeekHide this!Advertise here!
Air on the G string CarlyBoy Music 1 22nd May 2011 09:35 PM
Frequency range of acoustic 6 string? nordhaven Multi-Way 4 19th June 2008 07:41 PM
HELP me re-string my Telefunken 4530 lskelly1 Parts 1 24th March 2008 08:35 AM
Help - Tuner string replacement questions 74Elsinore Everything Else 2 28th December 2004 10:59 AM
WTB: Hohner B2V 5 string bass Brett Swap Meet 1 8th August 2004 10:13 PM
Copyright ©1999-2017 diyAudio
