Instruments and Amps Everything that makes music, Especially including instrument amps.
Want to make small inductor for tone circuit
Old 5th February 2013, 05:55 AM   #21
gingertube is offline gingertube  Australia
Cyclecamper,
The REAL values for your edification
Frequncy Band (centre) is set by the LC resonant frequency which you can calculate from
f = 1/ 2pi (LC)^-2
or 1 over 2 pi root L C (in words.)
OR cheat:
Resonant Frequency Calculator
2300 Hz and 0.047 uF => 101.88mH, call it 0.1 H
1250 Hz and 0.082 uF => 197.7 mH, call it 0.2 H
485 Hz and 0.22 uF => 489.48 mH, call it 0.5 H
235 Hz and 0.47 uF => 975.9 mH, call it 1 H
100 Hz and 1 uF => 2.5 H
You can match those values up with the Fender Part Numbers above.
Next go to Mouser or similar and search for those values. Should be cheaper than a Fender spare part.
Ian
Old 5th February 2013, 04:36 PM   #22
cyclecamper is offline cyclecamper  United States
Yes, no doubt the calcualated values are better thanthe real original ones. But I might be inclined to make my own before I try to find them, if it ever became necessary again.
Old 5th February 2013, 07:05 PM   #23
Loudthud is offline Loudthud  United States
Loudthud's Avatar
Just out of curiosity, what are the resistances of the inductors? I expect them to be quite high.
Old 5th February 2013, 07:09 PM   #24
dmills is offline dmills  United Kingdom
I think that ^-2 should probably be ^0.5?
73 Dan.
Old 5th February 2013, 09:53 PM   #25
Dan, Yes, I can never remember the "ALT-number" key sequence for square root sign (if there is one) so end up with a basic mistake like you point out.
Ian
Want to make small inductor for tone circuitHide this!Advertise here!
How to make a coupled inductor using Toroidal core? pandusambu Power Supplies 11 22nd January 2012 11:11 AM
Small inductor value question spooney Car Audio 1 14th July 2011 04:49 AM
tone stack switchable inductor hewo Instruments and Amps 2 29th March 2011 03:14 PM
How to make a multi tapped inductor coil? mcmahon48 Multi-Way 2 25th January 2009 06:50 PM
make my own 1mH inductor? gilbodavid Parts 1 17th May 2007 11:16 AM
Copyright ©1999-2017 diyAudio
