Instruments and Amps Everything that makes music, Especially including instrument amps.
Hybrid amp design
Hybrid amp design
Old 4th January 2013, 12:25 PM   #31
m145mcc is offline m145mcc  United States
Duly noted, ill go back to the previous one.
Old 4th January 2013, 12:44 PM   #32
ok after thinking about it I'm gona go buy a few books before I waste any more of the forums time. I appreciate your patience, I clearly don't know as much as I did thought about analog circuits.
Old 4th January 2013, 02:34 PM   #33
Ok so I'm feeling good about this one... I hope I properly cold biased the first stage. Or should I hot bias the first stage (attenuate) then cold bias the second.
Old 4th January 2013, 03:21 PM   #34
doozerdave is offline doozerdave  Canada
doozerdave's Avatar
I don't think you'll be happy with what you've done there. Rk of 39k will give you a fuzzy (almost fluffy) compressed sound with no headroom. If you're looking for a good wide range of overdrive I think you should go with a DC coupled cathode follower. Read this, all of it. DC Coupled Cathode Follower
-Dave
Old 4th January 2013, 03:23 PM   #35
Thanks, I will. While I have you, would it be a good idea to use a limiter for the output.
Old 4th January 2013, 03:31 PM   #36
doozerdave's Avatar
You will want to have an output level control. Take a look at the bottom of the AC Cathode follower page and you'll see an example for an effects loop. The send level control is what you want to do. It's simple and doesn't affect the tone.
Also, have you decided what to do with your heater voltage? If you don't have 12.6V anywhere you might want to regulate down from your 40V supply and have a nice, stable 12.6V DC heater. With only 1 tube the load will only be 150mA.
-Dave
Old 4th January 2013, 03:37 PM   #37
I was going to grab a 250va toroidal transformer from parts express then either use a regulator or a ziner to drop it down. thanks for the links.
Old 4th January 2013, 03:49 PM   #38
doozerdave's Avatar
That little hammond transformer that I linked earlier would be perfect (and more efficient) for heaters, but then you'll have multiple transformers. It easy for the cost of amps to creep up. haha...
-Dave
Old 4th January 2013, 03:50 PM   #39
I really hate sounding stupid, but I couldn't figure out how to order one. Do you have to go thought a distributor or something?
Old 4th January 2013, 03:54 PM   #40
doozerdave's Avatar
No worries, you're just getting into it
166F6 Hammond Manufacturing | 166F6-ND | DigiKey
-Dave
Hybrid amp designHide this!Advertise here!
Hybrid tube headphone amp design ashok Headphone Systems 21 30th December 2012 06:17 PM
any suggestions for a mid-amp transformer for a hybrid design... like this circuit... bassetrox Tubes / Valves 9 5th October 2011 09:47 AM
Hybrid Amplifier Design Luck Chip Amps 32 3rd March 2009 03:43 AM
Question about a hybrid PSU design reaction Tubes / Valves 2 11th October 2004 12:45 AM
Copyright ©1999-2017 diyAudio
