Instruments and Amps Everything that makes music, Especially including instrument amps.
Fender FM212R Problems
Old 19th February 2013, 01:49 AM   #231
badraven is offline badraven  United States
badraven's Avatar
Location: The heart of the South, in other words -Redneck Territory lol
Well this is depressing.
If at first you dont succeed, perhaps it isn't your bag. Lol...
Old 19th February 2013, 01:55 AM   #232
badraven's Avatar
JMFahey actually what you say about removing everything to the right of C40 makes sense since the drive and such is all created in the preamp on this amp. So are you suggesting I build a power amp like you describe or are you suggesting I purchase a power amp? Do you have something particular in mind? Thanks!
BR
Old 19th February 2013, 01:56 AM   #233
ouimetnick is offline ouimetnick  United States
Send a message via AIM to ouimetnick Fender FM212R Problems
I'm not an electronic pro here, so I can only sit back and watch and learn like you. I have knowledge about certain amps as I've dealt with them before, but this isn't one of them.
I'm sure you will get to the bottom of this. You started with a busted amp, broke it further blowing fuses and all, then over the course of a hundred posts were guided into getting the thing (almost) working. You are close to finishing.
if you go the route and get a seperate power amp, may I suggest a Class D board?
Something like this.
http://www.parts-express.com/pe/show...number=320-303
You can just use one channel.
Old 19th February 2013, 02:05 AM   #234
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
If the heat-sink is getting to hot then the output transistor are passing too much current.
The first few stages of the amp are about voltage amplification so shouldn't affect it.
Then the bias stage gives the correct bias voltage to the output transistors.
You could try changing r95 and r96 to 3k3 and see if the problem goes away.
This would decrease the bias voltage so you might get some crossover distortion but it would prove where the problem is or isn't.
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 19th February 2013, 02:10 AM   #235
badraven's Avatar
Default Nigel
I have been sitting here for the last little bit thinking the same thing. I thought, if I change the right reisistor(s) I could cool the output transistors off and eve if it were to drop my power who cares, this amp has plenty of power. I will give this a try. Thanks!
Old 19th February 2013, 02:14 AM   #236
badraven's Avatar
Default ouimetnick
Thanks for the advice. If I can't correct this heating problem soon I think I will try this. Thanks!
BR
2x100W TDA7498 Class-D Amplifier Board 320-303
Old 19th February 2013, 03:34 AM   #237
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Just for kicks, connect the Power amp out to a (borrowed) amp similar to the one suggested by Chris in post #229 and hook it to your speakers.
If you like what you hear ...... now you know.
As of adding a new Power Amp PCB, for practical reasons please avoid Class D, ChipAmps, Class A, Zen, etc.
We are not "upgrading" or "modernizing" anything here, we are backtracking to a classic, simple, *well* proven design to be able to go onstage with this amp.
The least "surprises", the best.
Said new PCB should be able to supply around 100W into 4 ohms, when fed +/- 42V , to be able to use the current PSU.
Here simplest is best.
Old 19th February 2013, 05:04 AM   #238
gmphadte is offline gmphadte  India
Have u checked C40 for leakage or short.
Sometimes, a diode shows good when cold tested but does not work/opens in the circuit.
Check voltage across inputs of each op amp.
You can also check for forward voltages of diodes including BE junctions with power ON.
Gajanan Phadte
Old 19th February 2013, 05:39 AM   #239
Q16 and Q17 will not show the forward BE voltage as they r protection devices.
Gajanan Phadte
Old 19th February 2013, 10:16 AM   #240
chris661 is offline chris661  United Kingdom
chris661's Avatar
PREamp out!!
Using the power amp output in its current faulty state could destroy any subsequent equipment.
I think that's what you meant, but I feel we should be clear on this point.
Chris
PS - to the OP, have a look on eBay for Samson Servo. There's a few bargains to be had, if you can get one to fit nicely in the cabinet.
Fender FM212R ProblemsHide this!Advertise here!
Fender help Docc25 Instruments and Amps 3 2nd January 2013 11:18 PM
1970s fender champ givin me problems beauxweiss Instruments and Amps 4 21st February 2012 05:53 PM
MiniWatt N3 problems, oscillation thumping and RF/motor problems. Destroyer OS Tubes / Valves 18 6th July 2010 01:14 AM
Fender Adjustments JDeV Instruments and Amps 6 7th April 2006 09:17 PM
Another Fender on the bench. Netlist Instruments and Amps 3 6th March 2004 09:03 AM
Copyright ©1999-2017 diyAudio
