Instruments and Amps Everything that makes music, Especially including instrument amps.
Auto capacitor "drain" fixture
Old 11th December 2012, 05:07 AM   #11
cyclecamper is offline cyclecamper  United States
Sorry if I'm not making much sense, not having a good day.
Old 11th December 2012, 05:37 AM   #12
Enzo is offline Enzo  United States
Or put another way, if you are a one-in-a-million guy, that just means there are 10 of you in New York.
Old 11th December 2012, 10:25 AM   #13
Rundmaus is offline Rundmaus  Germany
Rundmaus's Avatar
Originally Posted by cyclecamper View Post
Is there any reason I can't make all my amps so they are safe after 5 minutes? Or would that just forster bad habits that kill me working on someone else's amp?
It is good practice to ensure that any HV cap is sufficiently drained before working on a circuit - a bleeder, a series resistor or a choke might have gone open circuit, a cap downstream of some regulator circuit might still be charged, whatever. Especially if the amp hasn't been constructed by you.
If I am working on a circuit that has been powered on before, I usually leave the DMM connected to the HV rail I am working on, so the '0.xxx V' reading is always in sight.
Greetings,
Andreas
Old 12th December 2012, 08:43 PM   #14
Struth is offline Struth  Canada
Banned
Hi Guys
If you encounter an amp without bleeder resistors, add them in.
You do not need a "fixture" to drain caps. At most just a loose resistor and an alligator clip. Clip the lead onto one end of the R and the other to ground, then touch the free end of R to the cap.
DO NOT use less than 1k. Make it a 5W to have plenty of distance between your fingers and the leads.
The TUT-series always states to add bleeders, and the projects in TUT3 and TUT5 all have them.
I did not read this entire thread but the second post gave the only answer required.
If servicing old Marshall amps, some disconnected the caps from the circuit where bleeders were so the caps stay charged up if you mistakenly use the standby switch - a completely unnecessary device on a guitar amp.
Also, anything below 300V or so is considered 'safe".
Have fun
Kevin O'Connor
Auto capacitor "drain" fixtureHide this!Advertise here!
Luxman Integrated Amplifier L550 ("L-550") Capacitor Replacement in the Power Supply tiefbassuebertr Solid State 20 18th June 2017 10:03 AM
TNY256 - what is that "Y1 Safety" capacitor for ? nowhere Power Supplies 24 22nd June 2012 04:23 AM
Capacitor and resistor book - "must have" items for DIYers siliconray Siliconray Online Electronics Store 1 21st October 2011 12:16 PM
The Auto "For Sale" Thread jpruden Swap Meet 15 15th September 2008 04:48 PM
Circuit diagram for "Auto Sweeping" square wave generator patwen Digital Source 2 8th February 2002 05:07 AM
