Instruments and Amps Everything that makes music, Especially including instrument amps.
MESA STRATEGY BIAS MOD
Old 15th November 2012, 06:13 AM   #1
blackarab is offline blackarab  United Kingdom
Default MESA STRATEGY BIAS MOD
LOOKING FOR SOME HELP WITH ADDING TRIMPOTS AND RESISTOR TO THIS AMP ,NEED TO KNOW IF I NEED 1 OR TWO TRIMPOTS ,VALUES ETC MANY THANKS.
Old 15th November 2012, 06:22 AM   #2
Enzo is offline Enzo  United States
How about post or link a schematic for this model?
Old 15th November 2012, 08:31 AM   #3
Default mesa strategy
Hi Enzo thanks for your reply enclose a copy of the schemetic for you ,many thanks.Click the image to open in full size.
Old 15th November 2012, 11:51 AM   #4
Simon B is offline Simon B  United Kingdom
The url given for the schematic is correct, but it won't play nicely unless you've opened the page that references it:
The Free Information Society - Mesa Boogie Strategy 400 Electronic Circuit Schematic
My sprawling collection of schematics inclues the one below.
Engineer: One who can do for 10 shillings what any fool can do for 10 pounds.
Old 15th November 2012, 12:10 PM   #5
MESA STRATEGY 400 SCHMETATICClick the image to open in full size.
Old 15th November 2012, 07:55 PM   #6
snaggletooth is offline snaggletooth  United States
I assume you want to add an adjustable bias circuit. The two resistors in the schematic are not labeled; one between the two caps, and another to ground- form a voltage divider. The bias voltage is determined by the ratio of these two resistors. Look at the resistor going to ground. Replace it with a pot and a resistor, the resistor on the ground side to prevent the bias from being adjusted too low. You will have to figure out the value of the pot and resistor based on the current value of what's in there now.
Old 16th November 2012, 05:31 AM   #7
Thanks for your reply Snaggletooth ,the resistor to ground might possibly be 22 k does that sound about right would be the one to change ,looking at the schematic to 100k resistors the ground one to be changed is this what you are saying?
Old 19th November 2012, 05:37 PM   #8
Yes, replace that with maybe 10k to ground connected to maybe 50k pot with wiper connected to one side. You may also have to reduce the value of the resistor in the pi filter.
MESA STRATEGY BIAS MODHide this!Advertise here!
MartinLogan Bias Mod tyu Planars & Exotics 24 23rd November 2013 10:42 PM
MESA STRATEGY 400 blackarab Tubes / Valves 7 15th November 2012 02:14 PM
Mesa boogie strategy 110 to 230 volt conversion blackarab Power Supplies 0 20th August 2012 07:36 AM
mesa boogie strategy 400 amp blackarab Swap Meet 0 12th August 2012 02:44 PM
Mesa/Boogie Bass 400+ mod question fenderjazz Instruments and Amps 5 10th October 2011 07:50 AM
Copyright ©1999-2017 diyAudio
