Instruments and Amps Everything that makes music, Especially including instrument amps.
Voltage between chassis ground and earth ground
Old 14th November 2012, 09:24 PM   #1
haselphlunk is offline haselphlunk  United States
Default Voltage between chassis ground and earth ground
Newbie here so go easy on me. This is probably somewhere in the basic discussion section but I honestly cannot find it.
In short, the main question is should there be a voltage difference between the chassis ground of an tube amp and the earth ground? If so, what should it be? At length, I am converting an old 6V6 pushpull PA amp (Pacemaker PM 20) to a guitar amp. Warm up the amp and turn up volume and it is very quiet. Touch the metal chassis and it hums. Check the voltage between the chassis and earth ground and it is about 50 V AC, which seems a bit high to me. Checked another one of my amps and the chassis to ground voltage was 7 V AC.
My inclination is to just ground the chassis, but am afraid that the create a excessive draw on the power transformer and burn it up.
Again, newbie here so go easy. Thanks for your help.
Old 14th November 2012, 09:34 PM   #2
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Old amplifiers are often just flat dangerous, and this is no exception. I'd very strongly recommend that you fit a three wire power cord and bolt the green (safety Earth) wire to chassis.
If it were just your old carcass or mine at stake it may not be much of an issue, but children or pets could get hurt, and nobody wants that. So, yes, your inclination is completely correct.
All good fortune,
Chris
Old 14th November 2012, 10:11 PM   #3
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
According to modern regulations chassis has to be connected to the safety ground. I even heard that everyone who repairs an old guitar amp have to add 3-wire cable and ground it, otherwise can be sued.
The Devil is not so terrible as his math model is!
Old 14th November 2012, 10:12 PM   #4
DF96 is offline DF96  England
Mains filter caps can do this. Some old amps included a cap which is intended to electrocute the guitarist. Be careful. If possible get someone else to have a look at it.
Old 15th November 2012, 03:23 AM   #5
Tom Bavis is offline Tom Bavis
Tom Bavis's Avatar
No mains connected caps, according to schematic I have. But the primary of the transformer has some capacitance to the grounded core, which provides one current path, and there could be some leakage in the insulation as well. I wouldn't trust 50-year-old paper and wax to keep ME isolated form the power line - GROUND it!
Current though the green safety ground wire is normally close to zero. When it DOES carry current, you can thank your lucky stars that the current is not flowing through YOU!
Old 15th November 2012, 08:44 PM   #6
Thank you all for the responses. I will be grounding the chassis with a three wire cable this weekend. Right now I have it grounded with a separate wire.
There is also one remaining rather scary looking "paper & wax" filter capacitor that I will replace. Looks like the others have been replaced in the recent past, so I will leave them for now and see if this reduces the "floating" chassis voltage.
However, my fundamental question remains ...Are these old amps just designed to have a higher "floating" chassis ground voltage than that to earth ground? . . .or is this 50 V AC leaky voltage due to old worn out capacitor. I did measure the current from the chassis to ground and it is about 0.05 amps.
This is the schematic for this thing that I found on the internet.
Thanks again for your help.
Old 15th November 2012, 09:22 PM   #7
0.05A leakage current is very high, and if correct suggests a major problem. There is no capacitor to cause this so it must be something else - transformer insulation? However, check carefully that a previous fiddler has not added a cap which is not shown on the diagram.
Old 15th November 2012, 09:29 PM   #8
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
There will be leakage capacitance between the transformer windings and so a voltage passed across. So the chassis must be connected earth to be safe.
PCBCAD51 pcb design software. 2018 version out now. https://www.ebay.co.uk/itm/253272755...84.m1555.l2649
Old 15th November 2012, 09:47 PM   #9
12E1 is offline 12E1  United Kingdom
12E1's Avatar
Sure, but if the measured current was 50mA, that's huge for "leakage". The level of current to be expected due to the coupling between transformer windings would be a tiny fraction of that figure.
Old 15th November 2012, 10:25 PM   #10
indianajo is offline indianajo  United States
indianajo's Avatar
Hammond organ had a standard for earth connecting old chassis. 10k resistor connected between organ amp or preamp and "known earth ground". That known earth ground is the new 3rd wire of your power plug, if the wall plug is wired correctly. Measure voltage across the resistor with a AC VOM with more than 5 kohms / volt. (The cheapest RS meter is this high, typically). More than 4 VAC, the organ has to have the power transformer replaced. Before the earth ground is installed. To prevent insulation breakdown of the transformer (ie fire).
Not assured that the power transformer is the cause in the case of your amp, but cotton insulated wire could be the problem.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Voltage between chassis ground and earth groundHide this!Advertise here!
Chassis, ground, earth: connect? starbase218 Solid State 3 14th November 2007 09:56 AM
chassis ground vs. earth ground avid Chip Amps 4 10th November 2006 01:56 PM
first I earth the chassis for safety but why do I need to conect it to my ground... frank2395 Pass Labs 4 20th May 2005 01:15 PM
signal ground and earth ground ttray321 Tubes / Valves 9 3rd May 2005 04:14 AM
Chassis Ground = Circuit Ground --> Problems? rhildenbrand Pass Labs 5 23rd April 2004 02:08 AM
Copyright ©1999-2017 diyAudio
