putting an amp and speaker inside an acoustic bass putting an amp and speaker inside an acoustic bass - Page 3 - diyAudio
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 31st August 2013, 08:20 AM   #21
Nigel Goodwin is offline Nigel Goodwin  England
Originally Posted by deepbass9 View Post
I'm looking for a boost to about 20dbs or 30dbs. I don't need amp volume, just a little extra.
These aren't 'little' boosts, 20dB is an increase from 1 watt to 100 watts, and 30dB from 1 watt to 1000 watts.
I'll repeat again, for bass you need to move a LOT of air, so big speakers and high powers. For a moderate increase small power would be OK, but you still need a big speaker to shift the air.
Nigel Goodwin
Old 31st August 2013, 08:45 AM   #22
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Originally Posted by Nigel Goodwin View Post
Amping acoustic basses is a nightmare - my daughter keep insisting on taking hers to gigs, feedback is a HUGE problem. In the end I told her either take an electric bass, or take yourself and all the gear on the bus
Trying to put an amp and speaker inside the bass wouldn't stand a chance, and would you want a bass that heavy anyway?.
Edit: for a 'solution' how about buying a double bass? - these are considerably louder.
Use a sound hole damper. That will kill the acoustic feedback from the guitar, then you can turn the amp up to an external speaker.
Why you would wish to do this, is beyond me as it will make the guitar heavy and what about power to the amp and speaker connections?
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 2nd September 2013, 06:35 AM   #23
phase_accurate is offline phase_accurate
If I were you I'd build a small amp that is camouflaged as stool. Or is furniture forbidden as well ?
Charles
Old 2nd September 2013, 09:34 AM   #24
Stormo is offline Stormo
Default Feedback ? - Hmmm
Now the bass play very low notes with very long wavelength - several meters - what if the amplifier was inverting, hence playing out of phase with the signal ? then perhaps the feed-back issue wont be that bad ?
putting an amp and speaker inside an acoustic bassHide this!Advertise here!
Acoustic 370 Bass Amp jdiy Solid State 2 13th December 2011 02:09 PM
Putting a chipamp inside a speaker mihalis Chip Amps 9 29th May 2008 10:32 AM
Acoustic 370 bass amp Tekko Solid State 3 22nd September 2005 08:10 PM
Putting an external DAC inside a dvd/cd player Vinnie R. Digital Source 3 14th July 2003 04:31 PM
Putting amp on speaker cabinet Matti Everything Else 1 17th April 2001 12:35 PM
Copyright ©1999-2017 diyAudio
