Instruments and Amps Everything that makes music, Especially including instrument amps.
same transformer, different voltages?
Old 25th September 2012, 07:07 PM   #1
calx44 is offline calx44
Default same transformer, different voltages?
I had a post on here not so long ago about making a guitar amp. I have a preamp schematic that runs off 15 volts and a power amp chip that works best off about 25V. Can i use the same transformer/power supply? If so how?
Really basic question i know...
Thanks in advance
Callum
Old 25th September 2012, 07:38 PM   #2
R.I.P.
You tap off and regulate the high current 25V rails down to 15V
for the low current supplies for the preamp, leaving the 25V rails
directly connected to the power amplifier.
rgds, sreten.
Assuming you don't use a multitapped transformer ...
Old 27th September 2012, 06:11 AM   #3
OK, thaks for that. Makes sense really when I think about it.
Cheers
Callum
Old 1st October 2012, 06:49 PM   #4
I should have asked this before really, but how can i do this? with a voltage divider?
Callum
Old 1st October 2012, 07:44 PM   #5
R.I.P.
Zener diodes or regulators, you can't use a voltage divider for power
supplies. Look up some schematics of amplifiers to see how its done.
rgds, sreten.
Old 2nd October 2012, 04:38 PM   #6
Thanks. I have never really done anything with power supplies before, but I thought a divider wouldnt really work.
Cheers
Callum
Old 7th October 2012, 04:49 PM   #7
Minion is offline Minion  Canada
Depending on yer preamp you might be able to run it off of 25v.
If it is an opamp preamp and runs off a single supply you can most likely run it off of 25v , most opamps can run off of 30v or more and you will get increased headroom useing a higher voltage supply.
Cheers
Maybe post a schematic of your preamp design.
same transformer, different voltages?Hide this!Advertise here!
Power transformer HT/B+ voltages vivid Tubes / Valves 20 2nd July 2009 10:32 PM
Rail voltages from 15-0-15 volt transformer Bama Slamma Power Supplies 3 26th November 2006 10:27 AM
the best transformer rail voltages for gainclone? araven Chip Amps 2 30th September 2006 10:31 PM
Calculating secondary transformer voltages ash_dac Power Supplies 14 25th February 2006 04:36 PM
