Instruments and Amps Everything that makes music, Especially including instrument amps.
JFETs as switch in 2-channel tube amp
Old 24th September 2012, 05:37 PM   #21
muadib25 is offline muadib25  Sweden
muadib25's Avatar
Originally Posted by counter culture View Post
J111 & J112 are ideally suited to FET switching. If the source is treated as the input then it should be strapped to the gate using ~22k to ensure that Vgs remains @ 0V in the presence of an input signal. These FETs are apparently symmetrical.
Rather than try to reiterate the entire section from the book, I would suggest reading pages 408-421 of Small Signal Audio Design by Douglas Self which contain a comprehensive treatment of this subject.
Counterculture, thank you! It's added to my reading list, I am sure to cover a lot of things I am missing. As for the FETs I am using here, they are 2N5638, they belong to the "switches and choppers" class, same as J111, J112, J113 etc. Their ON resistance is at around 10-20 Ohm.
On the circuit I have the Drain facing the signal input and Source facing the signal output. But yes, these FETs are symmetrical.
Originally Posted by Mooly
You must drive the FET's via a resistor. The diode leaves the gate floating which is no good. Make sure that -14 volts is within the G-S rating of your chosen FET.
Now I get it!
My misunderstanding here was that from 0V and upwards(+) the JFET's resistance would not change, hence my proposal of using a diode.
So, if I get it right, when the JFET is ON (Vc=0V) the resistor will be conducting the necessary offset to the gate.
When the JFET is OFF (Vc=-13) there will be some of the gate's negative voltage present... Won't I be needing some caps after each JFET for not having DC injected to the signal?
Here is the circuit with the 22k resistors added:
Old 24th September 2012, 05:54 PM   #22
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
22k is too low resistance. Try something like 2.2 mega ohm or as high as possible, to lower loudness of Thump when switching. This resistor is needed to discharge gate charge, but unfortunately it provides parasitic path for control signal to output. T-configuration as I suggested before would be better in terms of Thumps.
The Devil is not so terrible as his math model is!
Old 24th September 2012, 05:56 PM   #23
Mooly's Avatar
Lets think about this... and I would recommend you try the design before building for real.
FET 1 and FET 2. Is the feed from V1B AC coupled such that this pont is at zero volts ? If so then both these FET's are tied to ground via the 2M2 and the unmarked resistor. The other side of each FET is AC coupled to the next stage and ground referenced again. So far so good. The gates can be pulled low (to a negative voltage) via the diodes.
FET 5 and 6. Not ground referenced on the output side as drawn ? Where does R19 go ? I'm guessing like the other FET's. That still leaves no ground reference. Add a high value resistor from the output of these FET's to ground.
Old 24th September 2012, 05:59 PM   #24
Wavebourn's Avatar
Mooly, he has potentiometers that provide path to ground, but needs some grid leak resistor. But such rough switching on very sensitive input of guitar amp is something I would never consider.
Old 24th September 2012, 06:05 PM   #25
Mooly's Avatar
Yes, but no grid leak. That is what I mean when I say add a high value resistor from output of these FETs to ground.
That is what you mean... yes
Old 24th September 2012, 07:24 PM   #26
muadib25's Avatar
I understand... Would a small cap in series with the signal path could isolate the control signal from the output?
Yep!
Oops, sorry for that. The unmarked resistor is 2M2 too!
Oops again. Yes, R19 is like the other resistors.
Ok, how about this?
Old 24th September 2012, 07:27 PM   #27
muadib25's Avatar
By the way, I got in touch with Kevin O' Connor from London Power in Canada. He told me I should have a split-rail control voltage of both polarities, say +/-15 Volts. This would allow the audio signal to live within the control range window...
Old 25th September 2012, 06:30 AM   #28
Mooly's Avatar
If by control volts he means the gate drive voltage then I don't agree. Look back at this,
http://www.diyaudio.com/forums/solid...ml#post1569428
It is a similar arrangement to yours. The input is AC coupled and both sides of the FET are ground referenced. As soon as the gate voltage goes above around 0.2 volts (relative to ground) then the FET G-S or G-D junction (depends which way round you have the FET and for these types it really doesn't matter as they are symetrical) will begin to conduct and DC will appear on the output. Just what you don't want. So the positive "on" voltage has to be kept lower than this value. The negative "off" gate voltage has to be more than the peak voltage you are trying to block.
At some point you now have to build the circuit and confirm (or otherwise) that it works as expected .
Old 25th September 2012, 11:28 AM   #29
muadib25's Avatar
Yes, I see now. Perhaps there is something I misunderstood. I will build the circuit and get back to you.
By the way, on your schematic I see you have the gate supplied with +/-9 VDC. Isnt it the same thing Mr. O' Connor suggests?
Again, thank you all one more time for the invaluable help and your patience!
Old 25th September 2012, 11:59 AM   #30
Mooly's Avatar
Yes, and I did it to highlight what happens when you increase the gate above around 0.2 volts.
The gate channel begins to conduct for real and to pass current. That gives a DC shift on the output which you don't want. Try it
JFETs as switch in 2-channel tube ampHide this!Advertise here!
Guidelines for switching N-channel JFETs to P-channel JFETs (and vica versa)? Test Electrix Construction Tips 9 24th January 2011 06:22 PM
Tube Amp Channel Switching bubbab74 Tubes / Valves 1 19th November 2009 04:29 PM
Tube Preamp L&R Channel different current draw tube cadet Tubes / Valves 0 21st January 2009 12:37 AM
P-channel JFETs more linear? lazthegaz Solid State 27 29th June 2004 12:50 PM
Copyright ©1999-2017 diyAudio
