Instruments and Amps Everything that makes music, Especially including instrument amps.
Building power electronics into a wooden cabinet?
Old 23rd October 2012, 05:25 AM   #41
cyclecamper is offline cyclecamper  United States
Chris A says: "...Remember that tubes cool by radiation. For that to work the tube needs to "see" a clear path into the rest of the room..."
That seems way too broad a statement, but something to think about. Yes, the internal parts are cooled by black-body IR radiation, at least thru the vaccum and to the envelope. And yes typical SCHOTT AR envelope glass untreated passes a lot of IR. But this is not quartz glass. A lot of the radiated energy changes to lower-frequency heat at the envelope and a lot is carried away from the envelope by convection, and some radiation and some re-radiation or the convection removal of heat generated when the IR strikes the box enclosure etc. It sure seems they are cooled MOSTLY by convection just because it works so much better than radiation. The preamp tubes don't produce much heat, but they obviously don't just radiate infra-red shining directly from the anode and its various internal radiators thru the glass and shine thru the solid metal Faraday shields into the room. No, the vast majority of tube TVs and radios did not have any direct line of sight from the tubes to the room, and relied solely on convection, and you could feel the heat pouring out the TOP, not radiating out the sides. Even with the chassis out in open space I can feel the heat rising from the top of the amp, yet I feel less horizontal radiation at shorter distances. A lot of heat is re-radiated or removed via convection from the top of the tubes, which are usually shiny like a mirror (is that part of hte getter coating?) probably blocking direct IR radiation thru the top. If the glass passed most of the heat as IR shining thru the glass, the envelopes in a non-fan amp would be cool to the touch...but they aren't. There are plenty of fan-cooled amps with the tubes completely enclosed and if it was mostly IR the housing would get hot and the tubes would be cool; but when the envelope is kept cool by convection there seems to be little radiation; the tube cage doesn't seem to get hot. It seems to me more like the envelope re-radiates and has significant convection-cooling. If you can cool the glass envelope with a fan there's very little direct radiation. I'd imagine much of even the radiation is re-radiation from the hot glass, not transmission of the radiation from the internal parts thru cool glass. Still, I'm going to consider that direct radiation...and perhaps letting my tubes have direct sight into the room. I'm just happy I don't have to listen to a fan if I do this right. I think seeing the red glow of the heaters makes us think it's got a lot of IR shining like light, but that heater IR is only a very small part of the heat compared to the plate under high voltage and current. And without real data, maybe I'm making too strong an opposing statement. I note the Peavey c50 does have the tubes in a cage to protect the rest of the amp from directly radiated heat.
Old 23rd October 2012, 01:17 PM   #42
Tubelab_com is online now Tubelab_com  United States
Tubelab_com's Avatar
There is plenty of radiated IR from a power vacuum tube. There is also plenty of conducted heat that can be removed by convection. Convection will also help remove reabsorbed IR. Plenty of that inside the box too.
The direct IR radiation can be felt in some of my experiments. It can also be reflected with shiney aluminum foil.
I could obviously feel the IR in both of these rather extreme experiments. Look at the reflection in the OPT's. That's why they get warm:
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 23rd October 2012, 03:35 PM   #43
Cassiel is offline Cassiel  Libya
Well, I haven't read the whole thread but......you can see the 6V6 almost touching the wood there in that picture. The wood gets warm but that 'Champ' has several years, same tube, no problems. Still, the second time around I placed the tubes in an horizontal position. You have to take care doing that with the 5Y3. The datasheet tells you how to do it, I don't remember it now.
Old 23rd October 2012, 08:13 PM   #44
Actually I appreciate the idea of taking advantage of any direct radiation out of the cabinet. I'm gooing to make use of that. Conducted heat????? Where, out the pins to the socket and wires?
Old 24th October 2012, 01:13 AM   #45
ChrisA is offline ChrisA  United States
That seems way too broad a statement, but something to think about. Yes, the internal parts are cooled by black-body IR radiation, at least thru the vaccum and to the envelope. And yes typical SCHOTT AR envelope glass untreated passes a lot of IR. But this is not quartz glass. A lot of the radiated energy changes to lower-frequency heat at the envelope and a lot is carried away from the envelope by convection...
Convection does cary away the heat from the OTHER stuff the tube itself heats by radiation.
An interesting experiment you can do (but don't) is to turn the power tube base up and submerge the glass envelope in a large container of room temperature water. The envelope will remain cool but the tube internals will not be effected at all. Even if you hold the tube's glass parts to a low temp. the insides do not seem to notice or care. In other words you can't get more power from a tube using water cooling. I think what this tells us is that the energy goes right through the glass and heats the inside of the cabinet or whatever is in the line of sight.
You are right, in the normal case the envelope do cool by convection but ERY little of the total energy is going into the envelope, most pass right on through.
Old 24th October 2012, 07:48 AM   #46
JRGuitarGuy is offline JRGuitarGuy
Banned
Power Plug - 6/12 Attenuator - YouTube
I wanna build something like this, I love that wood look man, old school/retro man just killer lol.
Old 24th October 2012, 06:27 PM   #47
Water-cooling certainly works for transmitting tubes if there's a significant heat-conducting extension of the plate thru the envelope.
From Wikipedia's page on "vaccum tube", definitely not the best technical reference:
"The method of anode cooling is dependent on the construction of the tube itself. Tubes used in consumer equipment have internal anodes, so cooling occurs through black body radiation from the anode (plate) to the glass envelope;[24] natural convection (air circulation) then removes the heat from the envelope. Tube shields that aided heat dispersal can be retrofitted on certain types of tube; they improve heat conduction from the surface of the tube to the shield itself by means of tens of copper tongues in contact with the glass tube, and have an opaque, black outside finish for improved heat radiation. The ability to remove heat may be further increased by forced-air cooling, and adding an external heat sink attached to the anode through the tube's enclosure. These measures are both implemented in the 4-1000A transmitting tube, whose anode was designed to operate while red hot, dissipating up to one kilowatt.[25]
The amount of heat that may be removed from a tube with an internal anode is limited.[24] Tubes with external anodes may be cooled using forced air, water, vapor, and multiphase. The 3CX10,000A7 is an example of a tube with an external anode cooled by forced air. Water, vapor, and multiphase cooling techniques all depend on the high specific heat and latent heat of water. The water-cooled 80 kg, 1.25 MW 8974 is among the largest commercial tubes available today.
In a water-cooled tube, the anode voltage appears directly on the cooling water surface, thus requiring the water to be an electrical insulator to prevent high voltage leakage through the cooling water to the radiator system. Water as usually supplied has ions which conduct electricity; deionized water, a good insulator, is required. Such systems usually have a built-in water-conductance monitor which will shut down the high-tension supply (often tens of kilovolts) if the conductance {measured in Mhos} becomes too high."
Old 24th October 2012, 06:31 PM   #48
That may be true, but your experiment only shows that the black-body radiation thru the vacuum is the limiting factor in the design, not whether subsequently outside the envelope convection or conduction predominates.
Old 30th October 2012, 11:06 PM   #49
So...in a normal Fender-type head cabinet with the chassis hanging upside-down, where only a small part of the output tubes have any direct radiation 'view' of the room, what color should I paint the inside of the cabinet? Is it better to make it all reflective with white or silver paint? Or is it better to paint it black so the IR turns into heat subsequently removed by convection?
Old 31st October 2012, 12:59 AM   #50
My point was you CAN'T cool the tube. Even if you place in under water. So you do what you like to cool the cabinet and other parts but all that has zero effect on the tubes. Maybe the tolled or the paint will last longer. The filter caps might last longer. But you can't cool the tubes with a fan or vents. OK you can cool the glass envelopes but this does nothing but make the glass cooler. Glass works just fine when hot.
Building power electronics into a wooden cabinet?Hide this!Advertise here!
Building cabinet opinion! Hameed Full Range 10 2nd April 2010 12:21 AM
Cabinet solutions to tame a wooden cone knightsound Full Range 0 25th May 2008 02:03 PM
Building guitar cabinet- help? otokomae Instruments and Amps 8 20th October 2005 08:41 PM
Building tube amp in wooden box(es) Saurav Tubes / Valves 37 4th June 2003 07:42 AM
Copyright ©1999-2017 diyAudio
