Instruments and Amps Everything that makes music, Especially including instrument amps.
LM4780 Guitar Amp Question
Old 6th August 2012, 02:00 AM   #1
alund is offline alund
Default LM4780 Guitar Amp Question
I'm in the process of building a mono LM4780 bridged amplifier identical to the application circuit in the datasheet, and I have a few questions:
I want the amp to be able to take a signal from either a CD/MP3 player, or an electric guitar. I assume that since the guitar signal is much weaker than the CD/MP3 signal, they will need to have separate inputs.
Can anyone point me in the direction of a pre-amp that I could use for the guitar input, and would it be best to have 2 separate volume adjustment pots at the pre-amp and LM4780 stages?
Andrew
Old 6th August 2012, 02:09 AM   #2
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
I've moved to instruments and amps forum (with a one week redirect) hopefully that should get the attention of the right people.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 6th August 2012, 02:41 AM   #3
Einric is offline Einric  United States
Einric's Avatar
If you want to keep it cheap I would pick up a pair of cheap op-amp preamps from ebay.
Old 6th August 2012, 10:05 AM   #4
razorrick1293 is offline razorrick1293  United Kingdom
an MP3/CD shouldnt need too much gain, a single op-amp stage with a fairly flat frequency response should be fine, a pot can be used in the feedback. A guitar preamp will need more gain, especially if your looking for some distortion, which will also require a frequency curve unsuited for music.
with a 120 watt output, are you looking for something to gig with? and are you looking for a fairly complex pre-amp that will get you a range of tone?
Old 6th August 2012, 10:37 AM   #5
geraldfryjr is offline geraldfryjr  United States
I would choose a schematic from a well known brand or one of your favorites.
My two favorites are the Marshall 8100 Valvestate and the Peavy Renown 400.
Either can be duplicated very easily !!!
FWIW
jer
Old 8th August 2012, 01:47 AM   #6
Any hints on where I can find schematics for the Peavy?
Looking at the controls for it, it seems like they have a 'pre-amp' built in if you use the high gain input, unless I'm mistaken...
Old 8th August 2012, 03:01 AM   #7
Yes it can be found here,
Peavey Renown 400 Manuals, Support and Troubleshooting - Amps
And the Marshal 8100 as well as many others can be found here,
Marshall Amps Info & Schematics
Enjoy !!!
jer
I have owned both of these amps and their sound second to none except to the fully tubed amps, I still have the Peavey Renown400 but my Marshall 8100 was stolen.
LM4780 Guitar Amp QuestionHide this!Advertise here!
Old guitar amp question rntlee Instruments and Amps 10 6th February 2012 09:23 AM
guitar amp question nhuwar Instruments and Amps 2 10th February 2009 05:28 PM
Guitar amp question nhuwar Instruments and Amps 32 21st January 2009 02:10 AM
Using LM4780 for Guitar amp - wondering Wynand Chip Amps 17 10th January 2007 05:28 AM
Brian's LM4780 for Bass Guitar Big Pete Chip Amps 19 1st November 2005 05:35 AM
Copyright ©1999-2017 diyAudio
