Instruments and Amps Everything that makes music, Especially including instrument amps.
Build guitar amp with 2 6L6 or 4 6V6?
Old 14th August 2012, 12:46 AM   #11
gingertube is offline gingertube  Australia
Dave,
"Each pair sees 8K", so parallel pairs see 2 lots of 8K in parallel, that is 4K.
You can see that Super Reverb replacement on this list clearly shows 4K Raa.
Hammond Mfg. - REPLACEMENT & UPGRADES - Tube Guitar Amplifier - Output Transformers
Tubetweaker,
Note the bassman replacement is 4200 Ohms Raa. That would suit either 4 off 6V6 or a pair of 6L6. You could easily build an amp which would do both options, just plug in a pair of 6L6 or plug in 2 pairs of 6V6.
Ian
Old 15th August 2012, 01:01 PM   #12
doozerdave is offline doozerdave  Canada
doozerdave's Avatar
Originally Posted by gingertube View Post
Dave,
Hi Ian. The Hammond replacement has multiple secondary taps to keep the primary at 4k. The original was 4k primary at 2-ohm speaker load, so I guess that puts it at 16k with an 8-ohm load. I knew something didn't seem right with my math vs. what I remembered from design time.
-Dave
Build guitar amp with 2 6L6 or 4 6V6?Hide this!Advertise here!
Guitar amp with 6P6S (6V6) and probably 12AX7 klopsson Instruments and Amps 17 1st January 2013 12:05 AM
Advice needed on new 6L6 ro 6V6 SE or SET build GloBug Tubes / Valves 39 23rd November 2011 05:22 PM
6V6 guitar amp design attempt Craig405 Instruments and Amps 29 2nd August 2006 05:48 PM
6V6 guitar amp... Guiness Instruments and Amps 3 24th November 2003 09:31 AM
6V6 Guitar Amp SHiFTY Instruments and Amps 2 5th August 2003 03:10 PM
Copyright ©1999-2017 diyAudio
