Instruments and Amps Everything that makes music, Especially including instrument amps.
Hammond AO-29 conversion
Old 28th July 2012, 09:05 PM   #1
scrimpu is offline scrimpu  United States
Default Hammond AO-29 conversion
I have a Hammond AO-29 amp that I would like to convert for guitar, I would like to keep it as close to stock as I can for now. Does anyone know how I can eliminate the expression pedal volume control? I would like to replace it with a simple volume pot but its quite a complex circuit that I have never encountered before.
Old 29th July 2012, 12:38 PM   #2
Kay Pirinha is offline Kay Pirinha  Germany
The AO-29 amp was used e.g. in the M-3 organs, right? So we have the schematics here. It's quite a complex circuitry with many components which are of no use in a simple guitar amp.
The expression (= volume) pedal actuates the differential variable capacitor between V4A and V4B. You'd eliminate everything between C9 and R37 and replace it by a 1 M audio taper potentiometer, hot end tied to C9, wiper to V4B, pin 7. To start with, use terminal "A" as the input.
Have fun!
Old 29th July 2012, 03:36 PM   #3
Yes, its from a 1957 M-3. I have removed al the vibrato percussion stuff and have wired terminal "A" as my input. I was unsure how to couple V4A to V4B since they are not phyisically connected in the expression pedal assembly, its just metal plates with a gap inbetween. Also this amp has a field coil speaker I want to change to a PM, as I understand all I need to do is put a 700ohm 30+ watt resistor in place of the coil, is this correct?
Old 30th July 2012, 04:24 PM   #4
indianajo is offline indianajo  United States
indianajo's Avatar
yes, a 500 to 1000 ohm 30 watt resistor should be fine to replace the field coil.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 30th July 2012, 09:38 PM   #5
I have wired up a pot between C9 and R37 and I have sound but only with the pot turned down to almost zero, it gets slightly quieter as I turn it up and goes silent about half way. How is it that more resistance equals more volume? Also whats the point of the 1.5 volts on pins 3 and 8? I have not seen this before. I am starting to think I will have to gut this thing and start over, these hammond amps are way more complex than need be.
Old 31st July 2012, 04:40 PM   #6
indianajo's Avatar
What pins 3 & 8? I/O on Hammond stuff is labled with letters until they went to AMP connectors.
Organ players ride the gain a lot, since pushing the keys harder doesn't do anything. The variable capacitor gain on the Hammond amps is WAY more reliable than the pots used on swell in early Baldwins or the CDS cell, light bulb, and cardboard baffle, used in other brands. Why don't you buy a variable capacitor from tonewheel-general.com or some other M scrapper? You don't have to attach a pedal to it. Just put in a wood box so you don't kick it on stage and bend it.
You can change the overall gain by fooling with R25 and R26 on the captain-foldback.com schematic.
Old 3rd August 2012, 04:52 PM   #7
ab0ez is offline ab0ez  United States
My best advice is to completely gut it and start over with a clean sheet of paper.
Old 4th August 2012, 03:47 AM   #8
Sorry I was refering to pins 3 and 8 of V4 on the schematic, I see now its part of the bais circuit, I was up way too late and must have been looking at the schmatic wrong. As far as the volume control issue Im thinking I should just couple V4a to V4b and place volume circuit elsewhere.
Old 4th August 2012, 12:45 PM   #9
My thoughts also!
He'd better remove everything besides the transformers and the output stage, buy one or two more 12AX7s, some potentiometers, have a proven schematic from the web and start constructing.
Best regards!
Old 4th August 2012, 09:00 PM   #10
Anyone know the specs for the expression control variable capacitor? I dont see the values for it on any schematics.
Hammond AO-29 conversionHide this!Advertise here!
Hammond or Everett AO-48 chassis Aidan135711 Instruments and Amps 14 11th October 2014 05:24 AM
Hammond ECL86/6GW8 conversion nightanole Tubes / Valves 25 21st March 2010 02:05 PM
Hammond guitar amp conversion bluestube Instruments and Amps 11 27th July 2009 02:09 AM
Hammond L-100 conversion rafaelblock Tubes / Valves 0 19th February 2008 06:16 PM
CDM 2/29 Problem HELP! Bassivus Digital Source 29 23rd December 2007 11:00 AM
Copyright ©1999-2017 diyAudio
