Instruments and Amps Everything that makes music, Especially including instrument amps.
Need Help with a 1996 SWR Workingman's 12 Combo Amp
Old 19th July 2012, 03:37 AM   #11
KP11520 is offline KP11520  United States
KP11520's Avatar
Hi Chris and Enzo,
I figured I would use a continuity tester to see if one of the three red leads is a ground but I need to get under the main board. As when I check the 15 Volt rails. BUT (and I'm talikin about a BIG Butt), the three Power Amp transistors are attached to the heatsink on the back. Can I unscrew them and separate them off the heatsink and reassemble them later with no problems?
I can post pictures if that would help!
And sorry Chris, you actually are still in your prime. I am closer to Enzo's end of the spectrum. (although I sure would like to be where you are again! Sorry Enzo)
Kudos Chris, you are helping an old guy with electronics that's almost 3 times your age and you are light years ahead!
And Enzo is just loaded with info and experience and a gift to guys like me.
Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner?
Old 19th July 2012, 07:21 AM   #12
phase_accurate is offline phase_accurate
Well 80 Watts is not super beefy. Don't know how loud is loud for you. I recently heard someone with such a combo playing live and for that gig it was loud enough but that wasn't a rock band.
I don't know how loud they uaually pop when turned on but somem pop is definitely normal because this amp diesn't have any type of delayed speaker relay. As long as the driver can take it this might be an even better solution form the reliability point of view.
There is a simple test that would show whether a problem is within the first part of the preamp: Feed some signal into the effect return maybe from some MP3 player or the like and check whether you can go louder.
Charles
Old 19th July 2012, 06:12 PM   #13
chris661 is online now chris661  United Kingdom
chris661's Avatar
Originally Posted by KP11520 View Post
Hi Chris and Enzo,
Regards//Keith
You should be fine taking those transistors off. Are you sure they're all transistors? Seems odd that there's 3 of them. Maybe one is a regulator.
Tell you what, switch the amplifier on (speaker connected) and leave it for a while. If the 3 chips on the heatsink are reasonably cool, then you're good to remove them. If they're really hot, then you can still take the heatsink off, but don't switch it on for any length of time: it might be difficult to replace them if they go pop.
When you come to attach them again, some heatsink paste wouldn't go amiss.
Chris
PS - which are the big power supply caps like?
Click the image to open in full size. Click the image to open in full size.
If they're like the latter, you can directly measure across them without removing the board.
Old 19th July 2012, 09:50 PM   #14
KP11520's Avatar
Hi Charles,
The distortion is with the gain and volume at less than 1/3 with both the passive setting and active setting.
Great idea! Having to go over the front end rather than the whole amp would be easier and less to do! (and less intimidating because of the "guesswork" issue).
I hope the problem lies in the preamp side. (Smaller PCB abd more accessible with less dismantling!
Thanks for another great idea my lack of experience wouldn't have thought of.
Regards//Keith
Charles
Old 19th July 2012, 09:53 PM   #15
KP11520's Avatar
Hi Chris,
The caps are radial unfortunately. Time to get out the Chop Saw. LOL
Would Arctic Silver thermal paste for computers suffice?
Thanks again!
Regards//Keith
Chris
Old 21st July 2012, 07:16 PM   #16
chris661's Avatar
The thermal paste you've mentioned will be fine.
+1 on Charles's idea on using the fx loop.
You could also try listening to the fx Send via some headphones to confirm your findings.
Old 22nd July 2012, 02:19 AM   #17
KP11520's Avatar
Well, Alrighty then!
Let the hacking begin.....
Where's that chainsaw?
Old 17th August 2012, 07:15 PM   #18
KP11520's Avatar
Hi Gang,
I bought most of the parts to build the AF tracer probe, except I am not having luck finding a "pen" shaped housing and a probe tip that can thread into whatever housing I find. I guess I could use a plastic cigar tube, but I want something a little thinner for more comfort and better maneuvering in tight spots. The metal pobe tip is evading me.
I am also the Executor to an Estate and that is consuming much of my time. Even when trying to decompress, I feel scattered because I know I should be doing something else. I will be able to focus a bit more come the middle of September.
Thanks for your support and I hope we can pick up where we left off!
If anyone has a line on some sort of pen shaped probe housing that will hold a 630 volt 0.1 uf axial cap and 1/2 watt 470K resister, the evasive tip and out to 2 wires, please point me in that direction. The same with the metal probe tip as well! Thanks again!
See you soon!
Regards//Keith
Old 18th August 2012, 12:06 AM   #19
Enzo is offline Enzo  United States
The tracer probe is a special input cable for an amplifier. You may have a amplifier dedicated to the purpose, but really any amp will work. You need a cap to block any DC in the circuit under test from your tracer amp. It is convenient to put it in the probe body, and I have built various probed in cigar tubes and find them comfortable to use. But the cap can just as easily be in the other end of the probe cable. Lots of room inside a big fat #70 Switchcraft plug for example. Or for that matter if your tracer amp is dedicated, put it inside the amp. All that matters is that you have a cap between the tip of the probe and the input of the amp. Doesn't matter where along the wire that cap lives. Same with the resistor. As long as it is on the right end of the cap, it can be anywhere.
A pen shaped housing? How about an empty pen?
Need Help with a 1996 SWR Workingman's 12 Combo AmpHide this!Advertise here!
HH guitar combo, 2*12" schematic pecamuzicar Instruments and Amps 6 1st November 2013 12:19 PM
Audio Precision SWR-122M and SWR-122F Switchers leadcoma Swap Meet 1 30th November 2010 02:31 PM
Any potential problems when using a combo potentiometer / power switch on a K-12 kit? Maxwell Smart Tubes / Valves 8 8th August 2010 01:05 AM
Eminence Lab 12 + Amp + Box combo metaverse Car Audio 57 8th January 2009 12:42 AM
MJL 4281 in hood amp - 1996 version with ccs sunrise Solid State 14 27th July 2005 07:48 PM
Copyright ©1999-2017 diyAudio
