Instruments and Amps Everything that makes music, Especially including instrument amps.
DIY Guitar Amp Oscillation
Old 12th July 2012, 04:24 PM   #1
Alexander Baev is offline Alexander Baev
Default DIY Guitar Amp Oscillation
Hello everyone.
I built the amp using attached schematic.
The problem is that it oscillates. Frequency of oscillation varies from about 1kHz to 20kHz. I do not hear all frequencies but I can see them with an oscilloscope. I can stop the oscillation and change its frequency and intensity by moving of anode wires of output tubes. However even when I find such place where the amp is not oscillate it is so unstable that I donít like such solution (it is enough to move even a little part of either wire for a couple of millimeters to start the oscillation). It is very interesting that changing the places of the anode wires (changing the phase of the OT) does not change the situation significantly (it only changes the frequency of the oscillation). In all tests Gain was at least in the middle (usually at maximum).
When I put signal input wire to ground oscillation stops.
DepositFiles
(Is there any better place for files?)
The sound of the amp is cool (when I find the place for anode wires at small level of volume).
What shell I check further?
Old 13th July 2012, 12:58 PM   #2
Nigel Goodwin is offline Nigel Goodwin  England
Does it oscillate with the volumes turned right down?.
Often it's down to weither a mistake in construction, or poor layout.
With valve amps you can at least remove valves to help isolate the problem.
Nigel Goodwin
Old 13th July 2012, 02:43 PM   #3
No
What do you mean under a mistake in construction? Schematic mistake?
What should I check primarily if it is poor layout?
If I put away any tube - oscillation stops. Without output tubes there is also no oscillation.
Old 13th July 2012, 04:06 PM   #4
Originally Posted by Alexander Baev View Post
No
No, a wiring error.
Post a picture of it's construction - but it's essential to keep inputs well away from outputs.
If oscillation stops when you remove any, then it must be feedback from the output to the input - does it do it with no input plugged in (I'm assuming you've used the shorting jack socket on the input?.
But as V1 and V3 are on different channels, only unplugging one of them should stop it, the other (as it's not connected) shouldn't make any difference.
Nigel Goodwin
Old 13th July 2012, 04:12 PM   #5
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
May be a feed back via the power or heater lines, too.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 13th July 2012, 04:19 PM   #6
I will a little later. (But the input is far from output).
If I put out the cable from the input (in this case the input is connected to the ground) - the oscillation stops. If I leave the cable in (the length of the cable is 4 meters) but put the signal wire to ground on not connected end of the cable at maximum volume level small oscillation is still detectible.
The problem appears only on distortion channel (V1,V2). I disconnected everything which has no deal with the distortion channel (the character of oscillation did not changed).
Old 13th July 2012, 04:20 PM   #7
How can I check this?
Old 13th July 2012, 05:07 PM   #8
Try adding some low value caps along the wires: a .1uF 600V across supply rail and chassis (or GND if chassis is floating), and see if oscillation frequency varies in frequency and or amplitude. Also add a "snubber" in the output stage. A snubber is a R-C series circuit in parallel to the output transformer, try for start, a resistor of about 1.3 times the load impedance (say, 6500ohm for a 5K output transformer), and a .01uF 2KV or more, and re-chech amplitude/frequency of the oscillation. If oscillation disappears, fix it in the circuit. Use the lower cap and the greater resistor that dampens the oscillation.
Caution: resistor not inductive (Means not wired wound), and be careful with high voltages in the circuit, and the resistor may become hot!!!
Old 13th July 2012, 06:30 PM   #9
Loudthud is offline Loudthud  United States
Loudthud's Avatar
The first thing to do is get the phase right. The output at the speaker should be the same phase as the input at Loop_out. The phase inverter circuit take care of making the feedback subtract from the input. If the phase is incorrect, reverse the PS1 and PS2 lines between the phase inverter and the power tubes.
There are no grid stoppers on the output tubes. Install a 10K resistor at the power tube socket in series with the pin 5 wires.
There is a mistake the way the schematic is drawn. It shows a virtual ground near F3 and F5 in addition to the ground on pin 4 of the DC supply for the preamp tubes. Remove the 100 ohm resistors. If you have not implemented the DC heater supply, leave the 100 ohm resistors in.
Old 18th July 2012, 03:00 PM   #10
I tried this - nothing changed.
Adding the snubber changes the frequency of oscillation but doesn't eliminate it.
DIY Guitar Amp OscillationHide this!Advertise here!
DIY Champ amp oscillation problem dcline Instruments and Amps 20 6th January 2012 10:00 AM
looking for a diy guitar amp. kostaz8 Instruments and Amps 14 2nd July 2009 04:44 AM
DIY Guitar amp AutoAudio Instruments and Amps 15 19th April 2006 01:32 PM
Guitar Pedal self Oscillation Question? walters9515 Instruments and Amps 0 6th April 2005 07:29 AM
DIY guitar amp guitargully Instruments and Amps 3 24th January 2004 03:02 PM
