Instruments and Amps Everything that makes music, Especially including instrument amps.
Mercury magnetics FBfd-om in matchless spitfire
Old 23rd June 2012, 12:10 AM   #1
bagudan is offline bagudan
Default Mercury magnetics FBfd-om in matchless spitfire
I have just completer a spitfire build
http://www.diyguitarist.com/Schemati...eSchematic.bmp
I used an old output transformer from a teisco AMP, but it is Way to small, and overall the AMP sunds thin and Weak...
Just ten kilometers from my house, a guy is selling a mercury magnetics OT.
It is made for a delux reverb, so the primary is 8k, and I believe the spitfire uses a OT with a much lower primary impedance. 6k or sommerens like that
I am sure it Will work, but curious to hear if there are anyone out there, Who believe that the original/untraditional OT in a spitfire is important in a build like this?
Old 23rd June 2012, 12:11 AM   #2
Sommerens= something
Old 23rd June 2012, 12:13 AM   #3
Oh, obviously this transformer is interesting because I Can get it cheap, and save the expensive shipping from abroad
Old 23rd June 2012, 02:21 AM   #4
Printer2 is offline Printer2  Canada
8k is perfect for EL84's.
Old 29th June 2012, 04:48 AM   #5
shanx is offline shanx  Canada
The spitfire output is designed around a 4 K primary. But having said that, the Mercury Mag transformer is going to be quite/very good. If it has multiple secondaries, you can ''mismatch'' the speaker impedance to reflect back the load to get about 4K primary.Hope this makes sense: Connect an 8 ohm speaker into the 4 ohm secondary tap. You reflect back to primary at 4K instead of 8 K. That should get you to an optimal impedance. If you have a 4 ohm speaker that may drive it a tad hard. 16 ohm cab can plug into 8 ohm tap.
Old 29th June 2012, 05:02 AM   #6
PS: Printer2 is right that EL 84s like the 8K. Even if you match the speaker taps, the Mercury OT will sound very good and you will only get a slightly lower volume. It will not blow anything up. The deluxe reverb OT I believe is rated much higher voltage etc than the spitfire.
Old 29th June 2012, 07:15 AM   #7
Thanks for the replies...
it only has an 8 ohm tap on the secondary....But IŽve got both 8 ohm and 16 ohm speakers that I want to try out.
IŽll install it over the weekend, and let you know what sounds the best....
Old 2nd July 2012, 09:02 PM   #8
Hooked up the output trandsormer tonight, with an 8ohm speaker.
The first impression is a much better sound and way more bass! But the volume is not impressive? And there is no gain/distortion what so ever. Volume almost fades out when toneknob is turned towards the bass side?
The voltages seem fine:
Powertubes:
pins 7: 351 vdc
pins 9: 352 vdc
V1
pins 1,6: 150 vdc
pins 3,8: 1,25 vdc
V2
pins 1,6: 253,258 vdc (should they be exactly the same?)
pins 3,8 : 66 vdc
B+ is 356 vdc
1st 33uf cap 356 vdc
2nd 33uf cap 354 vdc
1st 22 uf cap 335 vdc
2nd 22 uf cap 323 vdc
heater voltage (read between pins 4,5 - 9) is 6,8 vac ( a tad high?)
Cathode resistor is 150 ohms, and the voltage across the resistor is 13,2 vdc
Plate voltage pins 7-3 reads 338 vdc
Using the weber bias calculator gives 14w/41ma per tube
i know this is hot, but shouldnŽt it be biased hot?
Old 2nd July 2012, 09:06 PM   #9
Sorry
Forgot to post the schematic:
Old 2nd July 2012, 10:12 PM   #10
tictac is offline tictac  United States
The Deluxe Reverb had an OT with 6.6K impedance... the Princeton Reverb is the one with the 8K OT.... If it truely is a Deluxe Reverb OT you've likely got an OT with a 6.6K secondary...
just sayin....
TT
Mercury magnetics FBfd-om in matchless spitfireHide this!Advertise here!
anyone built the matchless hotbox? Thebrain Instruments and Amps 20 9th February 2014 09:26 AM
Matchless spitfire el84 dissipation Cassiel Instruments and Amps 37 18th May 2011 12:33 AM
Anyone else having problems with Mercury Magnetics transformers? reallyjake Tubes / Valves 5 18th December 2007 07:24 PM
Matchless Lightning v Spitfire gtrbryan Instruments and Amps 5 15th March 2007 02:57 PM
Mercury Magnetics Andrewbee Tubes / Valves 3 29th May 2005 03:21 AM
Copyright ©1999-2017 diyAudio
