Instruments and Amps Everything that makes music, Especially including instrument amps.
Power tube squeeling on standby?!
Old 5th June 2012, 02:46 PM   #1
Jclay85 is offline Jclay85  United States
Default Power tube squeeling on standby?!
I'm having a very strange issue with an old National amp I picked up. It's an old Westwood model, with 2 12ax7's, a 5y3, and a 6v6. When I got it I opened it up and noticed one of the coupling caps leaking so I went ahead and replaced it, along with another coupling cap and the filter caps. It used one of those old Mallory can caps so I found a suitable replacement from tube depot. I also went ahead and added a 3 prong cord. I grounded it to a power tranny lug.
I also got new preamp tubes and a new 6v6. I purchased the vintage 6v6 used off eBay from a reputable seller who claims it tested strong.
Now, when I turn the amp on, it plays ok, but with an annoying buzz. It does get louder when I turn the amp up, and I'm thinking this is just typical dirty power, etc?
What really concerns me is the fact that when I put the amp on standby the power tube starts squeeling. Not through the speaker, but noise emitting from the actual tube. I looked at it and it was emitting a bluish slightly flickering light like it was shorting or something? I have no idea. Any ideas?
Old 5th June 2012, 03:01 PM   #2
Osvaldo de Banfield is offline Osvaldo de Banfield  Argentina
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
How do the stand by switch acts? Cuts +B, place a large negative bias on 6V6īs...?
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 5th June 2012, 03:06 PM   #3
Thanks alot for taking the time to respond. I'm not exactly sure how to go about determining how it acts. How would I go about doing that?
Old 5th June 2012, 03:16 PM   #4
Default pics
If it helps, here is a picture of the inside of the amp:
And here is one of the exterior configuration:
Old 5th June 2012, 05:16 PM   #5
Squealing what? Power transformer, speaker, output transformer?
I ask the way the stand by switch is wired, because in this manner it is easiest to identify where is the issue, after or before that switching.
Old 5th June 2012, 06:15 PM   #6
Its literally the power tube that is squealing. Its a terrible noise. Not extremely loud or anything, about the decibel lever of a meowing cat... Strange comparison, but it's the first thing that came to mind...
How do I tell which way it is wired?
Old 5th June 2012, 07:29 PM   #7
How many time does the tube do it sound. Some tubes, and any other stuff makes noise when heating (because of dilatation of materials), and when cold (by contraction), like a rain noise on a steel sheet. but for few seconds.
Old 5th June 2012, 08:07 PM   #8
Loudthud is offline Loudthud  United States
Loudthud's Avatar
You can see from the picture that there is no switch between the transformer, rectifier and output transformer. Is there a model number anywhere? I can not find a reference to a "National Westwood" in any of my usual sources.
Old 5th June 2012, 08:20 PM   #9
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
How are you putting it on standby? I don't see a standby switch.
If the output tube is squealing, it seems to indicate that the loudspeakers may not be connected and the stage is oscillating.
We really need more information.
Frank
Old 6th June 2012, 01:23 AM   #10
Well, Im certainly learning a little about this amp through the process. First off, my apologies. They amp was already put back together when I initially posted and I just grabbed a picture of the inside of this amp off the internet. Upon close inspection, I realized mine has has some modification and apparently someone installed a standby switch of some sort. I took my amp back apart and took some pictures. I hope I didn't wasted to much of anyones time the first go around! Again, my sincerest apologies.
What I would really appreciate your opinions on at this point is:
1. Being that this amp didn't even come with a standby switch,should I just disconnect it altogether and fix this problem that way? If so, and idea which wires I connect when I remove them from the switch terminals?
2. Also, any idea what the hum/buzz might be caused by?
Here is my actual amp. Its a National Westwood Model N 6416 T by the way.
Thanks a lot for any additional help on this guys.
Power tube squeeling on standby?!Hide this!Advertise here!
zero standby power supply star882 Power Supplies 7 6th April 2010 06:58 PM
Standby voltages for tube circuits. ashok Tubes / Valves 23 25th September 2009 10:02 PM
squeeling toroids -- help CBRworm Solid State 5 7th February 2007 09:31 AM
low power standby current mode for Aleph 5 Adrie Pass Labs 16 22nd January 2005 08:19 PM
Standby power supply Prune Parts 11 11th July 2004 01:03 AM
