Instruments and Amps Everything that makes music, Especially including instrument amps.
18 watt toroidal transformer questions
Old 19th June 2012, 01:04 AM   #11
gingertube is offline gingertube  Australia
Kasper,
I prefer the resitors in the AC High Voltage feed wires to the rectifier tube as this reduces the stress on the rectifier tube as well.
Ian
Old 20th June 2012, 08:59 AM   #12
bagudan is offline bagudan
Thanks again for the good advisce. A pair of 100 ohms did the trick. B+ at the first cap is now 352. The schematic below calls for 354, so it should be fine.
However, there is a difference between the ceriatone layout Ive used, and the schematic Ive used. The two resisistors in the powersupply are 22k according to schem, but they are only 2k2 in the layout
http://www.ceriatone.com/images/layo...eCeriatone.jpg
http://www.diyguitarist.com/Schemati...eSchematic.bmp
When I check my voltage at v2 pins 1 and 6 I read 270 volts. The schematic says 250. I guess this would be different If it were 22k resistors in the powersupply?
Old 21st June 2012, 12:45 AM   #13
bagudan,
Going by the voltage drops across those resistors and the current I would expect to see at nodes C and D then the schematic values of 22K are correct.
Ian
Old 7th February 2013, 06:55 PM   #14
airfrankenstein is offline airfrankenstein
Bagudan,
I'm about to start a spitfire build as well and am in the process of choosing a transformer.
How did your build work out ? and is a toroidal transformer ok for the job ?
Francesco
18 watt toroidal transformer questionsHide this!Advertise here!
combining 18/18 watt amp and a bose acoustimass bass in a car TwinEdge Car Audio 3 19th June 2007 02:37 AM
FS: 18-0-18v Toroidal Transformer and More... Maples Swap Meet 12 7th August 2004 01:44 PM
Toroidal Power Transformer Questions Hercdriver Parts 18 21st April 2004 10:55 PM
Wanted: 300-400VA, 18-22VAC toroidal transformer Hyungo Swap Meet 7 30th April 2003 01:15 PM
FS: Plitron 225VA 18-0-18 Shielded Toroidal Power Transformers planet10 Swap Meet 3 11th August 2002 12:52 AM
