Instruments and Amps Everything that makes music, Especially including instrument amps.
Help with '65 Bassman!!!
Old 3rd June 2012, 08:11 AM   #1
rxbandit1 is offline rxbandit1  United States
Default Help with '65 Bassman!!!
Hi, I'm new to tube amp repair but have had good luck so far troubleshooting problems. I'm working on a friend's 1965 Fender Bassman and am having trouble solving a problem. Basically if you bump or move the amp the signal cuts out. There is a hum to the amp even when the guitar signal is coming through properly that I'm pretty sure is related to the original filter caps. When the guitar signal cuts out, the hum is still present but very, very quiet. I've checked for any loose wires, components, and grounds, and touched up all the solder joints. I replaced all the tubes with another set I know works. I thought I had discovered the source when I gently wiggled one of the power tubes that had a very loose socket it would cut in and out. So I replaced the socket and I still have the same problem. I sprayed a little component cleaner into the standby switch thinking maybe it was dirty or was shorting, but that didn't help either, and the problem seems unrelated to the switch. : ( The signal sometimes cuts out even when it's not touched. The oddest part is that if the signal cuts out and I have a guitar hooked up, I can play lightly and nothing happens, but the moment I hit the string a little harder, the amps cuts back in! Any ideas of what could be causing this or what else I can check?
Old 3rd June 2012, 09:30 PM   #2
kevinkr's Avatar
This belongs in Instruments & Amps per forum policy.
See header at top of both forums, but particularly tubes/valves:
Tubes / Valves All about our sweet vacuum tubes Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 3rd June 2012, 10:32 PM   #3
Minion is offline Minion  Canada
have you tried a new power tube in the socket you thought was loose ??
If you have an audio probe you can check the signal path to see where in the curcuit the audio is cutting out and narrow down the problem component ......
Old 4th June 2012, 10:48 PM   #4
famousmockingbird is offline famousmockingbird  United States
Have you checked/cleaned the volume pot?
Old 4th June 2012, 10:57 PM   #5
Bone is offline Bone  United Kingdom
Have you checked/cleaned the jack sockets?
Help with '65 Bassman!!!Hide this!Advertise here!
Bassman Schematic Alterations MellowTone Instruments and Amps 11 17th June 2009 04:48 PM
Jansen Bassman 50 guitargeek Instruments and Amps 15 17th June 2007 05:18 PM
Bassman guitargeek Swap Meet 0 3rd November 2004 05:38 AM
Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple the toasted Solid State 6 18th February 2003 03:13 PM
Antiphase wired second transformer in a 65-0-65 PSU to reduce ripple the toasted Parts 1 16th February 2003 07:06 PM
Copyright ©1999-2017 diyAudio
