Instruments and Amps Everything that makes music, Especially including instrument amps.
push-pull El34 bias question
Old 7th June 2012, 01:39 AM   #11
cancon is offline cancon  Canada
Thanks for that note, fmb, that is good to know. We're talking EL34's, BTW...not sure if that changes your response? Also by 10mA of screen current for both tubes (thus 90mA) I take it thats 5mA per screen?
I changed out the 39K bias resistor for 25K and now I can hit 80mA half-way through the bias pot's swing.
Old 7th June 2012, 06:10 PM   #12
famousmockingbird is offline famousmockingbird  United States
My mistake that was a typo, I did mean to type EL34 not EL84.
Old 8th September 2012, 05:33 AM   #13
Didn't know if I should start a new thread... here goes. Building a bias tester with 4 tube bases. I was wondering if it safe to use a 125V 0.3A rated rotary switch for selecting between test bases (2 poles, 4 position) for switching both cathode and plate. I'm thinking that even though there is no current draw in this scenario (simply measuring with a DVM), 500VDC will stress the switch...Should I jump up to a 125V@5A rating?
push-pull El34 bias questionHide this!Advertise here!
Bell 2420 tube amplifier. Bias question. 6v6 push pull The Donk! Tubes / Valves 5 30th May 2013 10:40 AM
EL34 Pentode in Push-Pull! Guijs Tubes / Valves 68 13th February 2013 09:08 PM
EL34 Push Pull in Class A arnoldc Tubes / Valves 29 17th May 2006 12:52 PM
EL34 Push Pull weirdness waner Tubes / Valves 32 11th December 2004 08:17 PM
Push pull class A bias question fragman56 Tubes / Valves 30 24th December 2003 08:23 PM
