Instruments and Amps Everything that makes music, Especially including instrument amps.
Buzzing in preamp circuit?
Old 2nd June 2012, 10:04 PM   #31
gootee is offline gootee  United States
It is possible that you have the wire from the signal to the non-ground end of the input resistor coming from the wrong lug on the input jack.
Can you check with your ohmmeter, between the center connector of the jack, outside the box, to the negative terminal of the battery?
If that is a low reading, then reverse the wires on the jack lugs, inside the box.
On the other hand, if it's correct as is, then there should be a low reading between the ground/shield/outer part of the jack (outside the box) and the negative terminal of the battery.
You could plug your cable in, to do those measurements, if that would be easier, since the other end of the cable will have a tip that should be the center conductor, which should not have a low resistance reading to the negative terminal of the battery.
Even easier would be to plug in the cable and then measure the resistance from the tip to each jack lug, inside the box.
Old 2nd June 2012, 11:32 PM   #32
JGAN is offline JGAN  United States
By "center connector," do you mean the tip?
Old 2nd June 2012, 11:49 PM   #33
HOLY !@#$%^&* AHHHH THANK YOU SO MUCH TOM!!!!!!! The problem was indeed the jacks being reversed!! How it worked like that and how I missed it I don't know, but I have never been so happy in my life!! Tone sounds so good
Thanks again Tom, and everyone else who replied!!
Old 3rd June 2012, 03:59 AM   #34
Woo hoo!! I love when that happens!!
But Loudthud is the one who caught it (post 14). So a big thank you to Loudthud!!
Tom
Buzzing in preamp circuit?Hide this!Advertise here!
Need help with this preamp circuit b0nk3rs Solid State 11 17th January 2007 08:55 AM
buzzing line drive preamp by the mod squad garbage Solid State 1 25th August 2006 08:09 AM
Mic Preamp, need circuit Dioda Everything Else 0 1st May 2006 07:03 AM
Mic Preamp from X preamp circuit? e.lectronick Pass Labs 2 13th November 2002 02:01 PM
Preamp Circuit cm961 Everything Else 9 15th June 2001 02:12 AM
Copyright ©1999-2017 diyAudio
