Instruments and Amps Everything that makes music, Especially including instrument amps.
raising filament voltages above cathode 6v6 please check.
Old 9th May 2012, 02:03 PM   #21
scott17 is offline scott17
Are you saying this?:
The amp is very quiet, and there is no output unless you hit the strings very hard.
Old 9th May 2012, 09:09 PM   #22
magnetman is offline magnetman  Australia
Hi Scott,
I was saying two things, the hum/noise had gone almost entirely after re routing the grounding. there is more I could do but I will leave that for the next attempt. the other problem was actually caused by a bad solder point in a speaker cable. So it was easily overcome. Thank-you for your reply though, I appreciate all the help I have been getting from everyone. There is so much to learn!
Luke
Old 9th May 2012, 09:40 PM   #23
Hi Luke,
I'm glad you got it fixed.
Rock on!
Scott
raising filament voltages above cathode 6v6 please check.Hide this!Advertise here!
Filament voltages - an idle curiosity kruesi Tubes / Valves 26 5th January 2010 04:52 PM
Standard tube filament voltages and currents ilimzn Tubes / Valves 5 4th January 2010 05:53 AM
SE 6V6 cathode resistor value bereanbill Tubes / Valves 7 24th May 2009 04:11 PM
Raising filament winding above cathode with a EZ81 in the circuit OK? G Tubes / Valves 3 15th May 2008 08:29 PM
ECC88 and PCC88 filament voltages sith Tubes / Valves 5 1st April 2004 09:30 PM
Copyright ©1999-2017 diyAudio
