Instruments and Amps Everything that makes music, Especially including instrument amps.
Magnatone #210 Power Stage
Old 14th March 2012, 08:28 PM   #1
Trout is offline Trout  United States
Trout's Avatar
Default Magnatone #210 Power Stage
I was just looking over this amp for restoration and found very little documentation other than a rough hand drawn schematic.
Anyway, I thought someone might be interested in this power section. Oddly rather than directly grounding the cathode & bypass cap on the power tube, they route it through the speaker/ot secondary?
Can someone give me any insight as to what the influences of this might be?
See picture.
Old 15th March 2012, 12:32 AM   #2
Loudthud is offline Loudthud  United States
Loudthud's Avatar
It's a form of negative feedback. You'll see it in some HiFi amps. If they are push pull, the 4 ohm tap will be grounded, the common terminal goes to one tube and the 16 ohm tap goes to the other. Before you ask, the 4 ohm tap is the center tap of a 4, 8, 16 ohm output transformer. Do the math, it takes twice as much voltage to make the same power in 16 ohms as it does for 4 ohms. There is a mod for the Dynakit Stereo 70 that uses this.
Old 15th March 2012, 02:14 AM   #3
Trout's Avatar
OK, That makes sense,
This is just a simple 4-5W SE amp, no extra taps, but I assume the concept is still the same.
First time I have ever seen this in a guitar amp.
Old 24th March 2012, 07:16 PM   #4
highfigh is offline highfigh
I just got one of these a couple of weeks ago and have only seen the same schematic. If anyone has an alternate schematic, I would like to see how accurate the hand-drawn one is.
Mine needed re-tensioning the tube socket inserts and that's all. It seems to be all original and it's from '61. Surprisingly, it doesn't hum or hiss- even the caps are OEM but I plan to replace those ASAP. I would like to replace the speaker with something that can handle a bit more but I don't think I want more sensitivity- it's loud enough as it is.
I had a BF Vibro Champ and this smokes that one, even though this only has a 6" speaker. The vibrato is great and it breaks up really nicely.
Magnatone #210 Power StageHide this!Advertise here!
60's Gibson 210 Redfoxfur Instruments and Amps 15 9th December 2014 05:55 AM
Sansui CD-210 Mod Help ! SoundsGreat Digital Source 1 30th December 2011 03:35 PM
need print for comtec 210 ? strat1953 Solid State 0 11th March 2010 08:09 PM
Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 tyler477 Solid State 1 31st October 2008 04:24 AM
210 mm dia navin Multi-Way 7 29th September 2003 04:04 PM
Copyright ©1999-2017 diyAudio
