Instruments and Amps Everything that makes music, Especially including instrument amps.
A quick question for the bass head guru's
Old 5th March 2012, 05:54 AM   #1
dachiz is offline dachiz  United States
Default A quick question for the bass head guru's
This being my first post I believe in this forum, I will try to be brief in story and short in my questions. I acquired a bass amp today that was being used to drive a pair of JBL d130a's in a single cab. Very early sixtyish' style, what I first thought was a homebrew with stencils, might be a little more than that. This is called a Heilman Falcon Super 4, has what I think is an Acrosound OPT and has a pair of EL34's in it with some IBM 12a??a..'s.. Being a pair of EL34's am I to assume that this a 50watt bass head?? It's going to be recapped here in a little bit and my son is chomping on the bit to have this done. We spun the drivers 180 degrees already and hooked up the JBL's to a small 15w practice amp and the speakers sound beautiful. Now I just have to remind the kid for now to be careful so he doesn't overdrive his lil practice amp and start clipping!! And you know what, I purchased this soley for the JBL drivers to restore a set of kit JBL C40 Harkness speakers cabinets I was given several years ago and "Tom" toss'd in the amp head because the vinyl matched and he did inherit it and knew I could slap in some Altec or something else later. Tom, if you ever read this, once again "Thankyou, and my son thanks you!!!"
Old 5th March 2012, 06:25 AM   #2
gingertube is offline gingertube  Australia
EL34 Application Data is here:
TDSL Tube data [EL34]
I would put a small wager on that 9th? entry down. 55 Watts Raa 3K4 Va = 400V.
Although..
If its an Acrosound Ourtput Tranny it may be running Ultralinear in which case you only get 37 Watts (sse 4th table entry).
Nice score.
Ian
Old 5th March 2012, 07:02 AM   #3
Default wow!!...possibly 55w tku sir for the info!
I don't play myself, my interests lies on the other end of things. I listen, critically at times to various genre types. So I'm just learning the basics for my own audio desires (baby steps practicing soldering skills soon with a stereo console pull amp) and will get around to this lil beastie!... Ian, my son Ian thanks you for the info.
regards
Craig
A quick question for the bass head guru'sHide this!Advertise here!
Yaqin MC10L Question for the Guru's Hi_Q Tubes / Valves 6 11th September 2011 12:03 AM
Need help from you bass-horn guru's, re-engineer a horn from drawing. Join Subwoofers 4 10th November 2010 12:45 AM
Quick bass reflex port question... revans Everything Else 26 8th March 2009 07:36 PM
Yorkville 400B Bass Head Repair Help cm961 Solid State 0 20th February 2009 03:47 PM
Question for op-amp guru's ALW Solid State 9 31st August 2002 01:02 PM
