Instruments and Amps Everything that makes music, Especially including instrument amps.
Tapco 4400 reverb problems
Old 29th February 2012, 09:13 PM   #1
dscottguitars is offline dscottguitars  United States
Default Tapco 4400 reverb problems
I have a Tapco 4400 dual reverb, solid state, unit that is not working. I replaced the fuse, and the power is there, input signal goes through and the controls for in/out level work. The meter works, the mute works, but the reverb and eq do not. I've looked extensively at the board and do not see any burned places.
Any ideas?
Thanks,
Daniel
Old 1st March 2012, 01:07 AM   #2
Enzo is offline Enzo  United States
I got one - link us to a schematic.
The vast majority of circuit failures do not result in burnt spots.
In any reverb failure, well any failure at all for that matter, isolate the problem. No reverb will either be the reverb pan, the cabling, or the support circuitry.
Disconnect the reverb pan and measure for continuity through its transducer coils - either end open?
With the thing running and reverb controls up, take the cables that went to the pan and touch the tip of each plug. One of them should make hum, and that is the return, and plugs into the OUTPUT jack on the pan. If that doesn't happen, then no reverb would happen.
With test signal applied to a channel input, scope the other cable - the drive cable - is there signal appearing there that woul;d drive the reverb pan?
Old 2nd March 2012, 07:12 PM   #3
DrSound is offline DrSound  Israel
Hi dscottguitars,
Send me your e-mail and I will send you Tapco 4400 reverb service manual.
Old 2nd March 2012, 07:39 PM   #4
I found out it's in the reverb pans. One of them was barely connect inside and that one works now. On the other, one of the coils has a short even though the wires and the unit look new. I was able to get it to work by moving it around and siliconed glued the wire to the brace to hold it in place and that seems fine.
Thank you all...
Tapco 4400 reverb problemsHide this!Advertise here!
Schematics for Denon POA 4400 Snorre Solid State 5 21st November 2013 10:56 AM
Looking for Tapco CP500 Schematics Zero Cool Solid State 1 27th May 2009 06:46 AM
Gibson Ga-20 rvt reverb problems blindbrett Instruments and Amps 1 11th November 2008 04:18 PM
Tapco power amplifier for sale Thims Swap Meet 0 25th March 2008 11:14 AM
denon 4400 or 6600 schematic? lt cdr data Solid State 5 28th August 2006 03:38 AM
