Instruments and Amps Everything that makes music, Especially including instrument amps.
10 Band EQ
10 Band EQ
Old 25th February 2012, 11:17 PM   #1
Fiddlesticks is offline Fiddlesticks
Default 10 Band EQ
I've been wanting to replace my Boss GE7 for a while with a 10 band EQ something like the MXR 10 band or the (discontinued) B.Y.O.C kit (graphiceq). I need it to be portable/on battery, so MXR goes. And I can't get the BA3812L chip locally.
Is there something similar to the BA3812L chip I can use?
Also, generalguitargadgets.com has a schem for a 6 band using TL074 chips (http://www.generalguitargadgets.com/...8044a841b3e85a). Can this be expanded to 10 bands?
Yes. I am a rank amateur.
Old 25th February 2012, 11:40 PM   #2
Default Facepalm
Ha lol. Google reigns supreme. Again.
Can this be run off single 9v battery you reckon?
TL074 10 Band Graphic Equalizer Schematic circuit - Schematic Circuits Elektropage.com
Old 26th February 2012, 05:28 PM   #3
Minion is offline Minion  Canada
The schematic shows it as a dual supply design not a single supply design so a single 9v won"t work unless you change the design for single supply ......
Old 26th February 2012, 06:16 PM   #4
razorrick1293 is offline razorrick1293  United Kingdom
Yes that 6 band circuit can be expanded into a 10 band design, the op amp stages act as inductors. 1/2piRF will tell you what capacitor values you want for a given frequency. looks like all the resistors are the same. so you could just choose a few apporximate values that fit into a similar series.
Old 26th February 2012, 06:18 PM   #5
a 9v battery can be used to make a dual supply of +/- 4.5v. which is shown on the first schematic.
Old 28th February 2012, 02:18 AM   #6
Ok, but the GGG schematic shows a single 9v supply connects to (a) and (b) OR 2x 9v connects to (a) (b) and (c). Does this mean it I can omit the (c) section entirely? I'm confused.
How would I add the extra bands? Add another TL074?
10 Band EQHide this!Advertise here!
3 band eq with ballance and gain jamie1107 Solid State 3 28th July 2011 02:52 AM
3 band eq with paramertic kendarmstat Analog Line Level 0 7th June 2011 04:20 AM
mec 3 band eq kendarmstat Instruments and Amps 3 2nd May 2011 02:59 AM
EQ band components ianmgreen Construction Tips 2 23rd April 2011 01:41 PM
3 band eq kendarmstat Analog Line Level 0 3rd April 2011 03:56 PM
