Instruments and Amps Everything that makes music, Especially including instrument amps.
Dean Markley T120-R fixer-upper project.
Old 13th November 2013, 08:14 AM   #31
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
Hello Tricktronix,
Find the schematic here:
Good luck,
Tarzan
Old 14th November 2013, 09:47 AM   #32
Tricktronix is offline Tricktronix  United States
Thanks Tarzan! Much Gratitude.
Old 12th March 2014, 12:16 AM   #33
andrewdare is offline andrewdare  Australia
hey there , just been fixing up my CD 120 as the speaker was fried put in an EVM12L
sounds fantastic , any info on these amps is hard to find ,
Old 5th November 2014, 10:06 PM   #34
mondogenerator is offline mondogenerator  England
mondogenerator's Avatar
Default it's been a while
Well, just dragging up a thread i posted sometime ago....
Just today received replacement valves, in 2 days from order no less! Watford Valves, very efficient people!
So the old mixed up bunch of cheap Chinese short tube 6L6GC, and a pair of Phillips ECG 6LLGC in tall tubes, are gone (ok I saved them for "just in case...")
The cheap Chinese ones were always red hot, the Phillips cool.
So through investigation i discovered what i guessed would be the closest to the original Phillips pair.
I open the boxes, and they are identical apart from the print colour. The green of the new valves, verses the white of the originals. So I guess there was a non-military version of this valve, perhaps a commercial version produced from mil spec version (since the originals are labelled 6L6GC rather than 8751)
In went the Phillips ECG str387 (8751a)....
My god! Everything is just rosey
Take my word. If you have one of these amps, with the original GEC 12AX7 in the preamp stages, DON'T replace them, not even EH. unless you have the ultimate valve.
The range of sounds...reissue 69 Strat, and Modern LP. Poles apart. Clean as you like with the Strat, warm bluesy mush if you want. The LP just rocks, though getting a pure clean sound is a little more difficult, being down around "1" on the preamp. So dial the guitar down.
Balancing the things I must do, with the things I'd like to do...This is a skill (or a luxury) amongst many that I do not possess.
Dean Markley T120-R fixer-upper project.Hide this!Advertise here!
dean markley valve head 120 watt mondogenerator Instruments and Amps 19 25th February 2012 07:09 PM
Dean markley DR-80 Pre Need help screamersusa Instruments and Amps 1 11th February 2009 09:16 PM
FS: Yamaha M-80 Fixer-Upper bluesmoke Swap Meet 6 1st May 2006 02:26 AM
Dynaco SCA-35 fixer-upper dorkus Tubes / Valves 7 19th May 2005 02:07 AM
Hafler 500 fixer upper for sale RADIOLEE Swap Meet 2 13th January 2003 01:56 PM
