Instruments and Amps Everything that makes music, Especially including instrument amps.
Old guitar amp question
Old 5th February 2012, 04:22 AM   #1
rntlee is offline rntlee
Default Old guitar amp question
I've recently come into possession of an old '65 Supro 16T guitar amp. It's completely original and I tried it briefly to see if it still worked. It powers up fine and plays well but has a slight background hum. I see it has an old Mallory FP capacitor in the power supply. Am I courting disaster powering this thing up? I haven't turned it on since I noticed the hum.
Edit: I can't find a Supro schematic but it's apparently the same as this Gretsch.
Old 5th February 2012, 04:34 AM   #2
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
yes you are courting disaster. Old amps have a predilection for exploding their electrolytic caps with messy, smelly and destructive results.
Do a quick search in here on resurrecting old amps - there are plenty of threads on the subject
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 5th February 2012, 01:12 PM   #3
Just one other question,
I can't find the correct value 3 section FP cap (450v 20-10-10), is it ok to use a 525v 20-20-20 in it's place?
Old 5th February 2012, 01:43 PM   #4
eyoung is offline eyoung  United States
eyoung's Avatar
you could try it or just use individual caps , don't forget the cap on the 12ax7...
Elwood
"Lead me not into temptation...I can find it myself."
Old 5th February 2012, 01:48 PM   #5
GloBug is offline GloBug  Canada
Banned
Generally you can go up in voltage.
You should be careful raising the capacitance.
In this particular case you are OK. The 20uf in the Gretsch schematic is the first filter cap after the 5Y3 rectifier. You don't really want to raise this much, if at all, it will stress the 5Y3.
The other two should be OK to go from 10uf to 20uf.
You don't have to by a "Can cap" you can buy single smaller capacitors and install them inside the chassis.
Old 5th February 2012, 01:49 PM   #6
Banned
Elwood
What cap?
Old 5th February 2012, 02:36 PM   #7
BB62 is offline BB62  United States
If that cap physically fits it should be OK. The preamp and tremolo are both cathode biased. If anything it should have a little less AC line hum than the original circuit. Be careful in there.
Old 5th February 2012, 06:55 PM   #8
Thanks for the help, guys. I was thinking that an FP cap would be more "original"...though I guess I could leave the old one mounted anyway. It's a kinda desirable amp...the last one on ebay went for $700.
This is the interior: http://i247.photobucket.com/albums/g...e/CIMG4850.jpg
Would I also need to replace the black and the orange cap? Not all the ceramics too I hope?
Sorry about all the dumb q's.
Old 5th February 2012, 06:59 PM   #9
Banned
Yes give that orange and the black one a swap too, it also appears to be electrolytic.
Yes for resale value, keep the the old cap and tack the new caps underneath, or "restuff" the cap with three smaller ones.
The ceramics should be OK
Old 6th February 2012, 09:49 AM   #10
costis_n is offline costis_n  Greece
Leave the ceramics alone, they are the soul of your tone!
Old guitar amp questionHide this!Advertise here!
Guitar Amp Hum Question Trout Instruments and Amps 9 11th August 2013 05:29 PM
guitar amp question nhuwar Instruments and Amps 2 10th February 2009 06:28 PM
Guitar amp question nhuwar Instruments and Amps 32 21st January 2009 03:10 AM
question regarding guitar amp line out princeofnam Instruments and Amps 1 28th May 2008 11:28 AM
Guitar amp channel question Trepan Instruments and Amps 3 22nd May 2007 04:46 PM
