Instruments and Amps Everything that makes music, Especially including instrument amps.
Amps... where to start?
Old 5th February 2012, 09:50 AM   #11
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I'd start off with something dead simple, like the Ruby. For what it is, it sounds great.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 5th February 2012, 10:47 AM   #12
sendoushi is offline sendoushi
Originally Posted by Printer2 View Post
Best place to start is...
...what kind of music do you want to play? Just starting out, will you be interested in a practice amp for at home? I would suggest...
Professor Tweed
http://www.runoffgroove.com/professor1.mp3
http://www.runoffgroove.com/professor2.mp3
... and then a IC amp of 4-12 watts running into a 8" speaker.
Tube amps are nice to have but that can be for the next amp, right?
I want to play rock, blues... That kind of thing. At long term I want an amp to use everywhere (no problem with neighbors eheh) but since it's a first project , sure why not a practice amp?
I have all the time in the world so... I can wait so I can develop my knowledge and then advance to tube. That's why I've made this topic otherwise I would build a Framus right away ehehe.
The preamp may be needed to amplify the guitar enough to be used by the main amp. It can/will also have tone controls.
While tube amps are nicer, like the other poster said you can save it for the next project.
Oh I see what you mean. Does that Professor Tweed (by the way nice sound) do that already?
Valve amps are easy to build - but they are very EXPENSIVE to build - solid state amps are a fraction of the price for much higher powers.
It really depends what you're looking for and what style of music you play, but many guitarists prefer the lower quality of valve amps, the limited frequency response and high distortion are effects many seek.
As I said early, If I could, I would go right away with a Framus amp so... I like valve amps. But what you said is really relevant. I don't want to spend tons of money, at least for now.
Seems interesting. I guess I like a bit more the Professor Tweed but I don't know.
Thanks for the ideas by the way! Keep on replying!
I was checking yesterday the speakers of my Marshall Valvestate. The only things that i remember are that it is 100w each and Celestion Gold (for the cabinet idea). Kind of expensive these.
Old 5th February 2012, 10:50 AM   #13
Professor Tweed
Old 5th February 2012, 02:36 PM   #14
Printer2 is offline Printer2  Canada
The Professor Tweed was designed as a guitar pedal but it can work nicely as a preamp into a SS amp. It has a basic tone control as was the case when Fender Tweed amps were new. The tone control is a little different if you do not know how it works. If the volume control is at maximum you the tone control does not have any treble boost but as you turn it down it rolls off the highs. If the volume control is turned down some then the treble is bypassed around the volume pot when the tone pot is turned up. It actually works well.
Old 5th February 2012, 02:49 PM   #15
Well... I don't know what the hell you just said but it seems fine for my ears. So I'll need this Professor Tweed and then SS amp. Any SS amp already made? I have a not very interesting one laying around the house, a crate. Of course that then I want to build the ss amp also. I just need to start understand everything and what's the difference between the preamp and the amp. I thought it was all the same.
Old 5th February 2012, 03:56 PM   #16
Richard Ellis is offline Richard Ellis  Argentina
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Perhaps it seems you should go the SS route at this point as tube gear might dissuade you...The next part will be the speaker...to make the sound.
Guitar set-ups are usually referred to as the "Head" (The amplifier) a small unit atop a "Cab" ( Short for Cabinet, or speaker cabinet) The set-up has the amp atop a cabinet, rather industrial in nature, rugged, built to last....or rather built for travel....being moved around & capable of sustaining cosmetic damage but still functional. The "other half" of the equation is the speaker cabinet.
Guitar speaker drivers have a "tone" or sound all their own. Guitar speakers do not "faithfully", accurately reproduce the input signal....they all have tonal "personalities". A simple open-backed box, probably made of plywood & overbuilt, housing one 'Lead guitar type speaker will do you just fine for years to come.
__________________________________________________ ____Rick.........
Old 5th February 2012, 04:17 PM   #17
Thanks for the explanation. I knew most of what you said but still I really appreciate this reply.
From what i'm seeing, the Professor Tweed isn't that easy but it seems to me a good challenge! Some components I have like the transistors, some capacitors and some resistors but still... I have to buy a lot of these... Including potentiometers... I'll have to go to ebay!
Amps... where to start?Hide this!Advertise here!
Speaker protection and soft start modules from Aussie Amps chlorofille Swap Meet 5 18th July 2011 10:58 PM
SOFT START FOR POWER AMPS wattaniya Solid State 49 8th February 2011 02:57 PM
Time delay start board for tube amps gjo Tubes / Valves 4 26th November 2008 04:23 AM
Will start my new Gainclone from Start, Need Help samsagaz Chip Amps 4 27th May 2008 10:39 AM
Copyright ©1999-2017 diyAudio
