Instruments and Amps Everything that makes music, Especially including instrument amps.
GU50 Prototypes
GU50 Prototypes
Old 2nd January 2012, 07:41 PM   #1
matejsirk is offline matejsirk  Slovenia
GU50 Prototypes
Default GU50 Prototypes
Some time ago, me and friends decided that we make a few prototypes with GU50. The idea was to test as many different combinations. For input tube we decided for 6SN7, 6SL7, 6N1P, 6N23P, 6N6P, D3a, 6C3P, ECC83, ECC85, ECC81.
We made some SE prototypes, one of the PSE and the PP one. As the input tube we test: D3a, 6C3P (the best two), 6N23P, 6SN7, 6N6P (also very good - not enough gain), ECC83, ECC85 (not so good). The project is continuing. Now I'm working on the development of housing.
We found that the GU50 is one of the best, for me better than EL34 or EL84.
A couple more pictures of prototypes:
Old 8th November 2012, 12:25 AM   #2
fabioab is offline fabioab  Brazil
Hi, my prototype is a mix of Fender AB763 with 12Ax7 as phase inverter, and two Gu50 at the power.
ry50 - 80W - YouTube
Only volume pot.
Almost finished!
Old 8th November 2012, 12:58 AM   #3
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
GU50 Prototypes
Me too.
Also I found that it is better than that 6L6 clones like KT-88.
Here are my prototypes:
The Devil is not so terrible as his math model is!
Old 8th November 2012, 05:05 AM   #4
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
nice work sir wave,
I'm also planning to do a PP gu50 with 6n6p drivers or 6n1p....any schematics suggestion for a 50w amp?
Old 8th November 2012, 07:45 AM   #5
Jaap is offline Jaap  Netherlands
Jaap's Avatar
Schematics ?
Old 17th November 2012, 11:20 PM   #6
Hi, I would state some "strange" behavior of my ampli.
When I cranck (or close cranck) the volume pot, it starts a riiiiiiizzzzzzz. Obvioulsly the amplifier is totally saturated and crunched. It happens without the guitar plugged too.
Some Ideas what could cause this effect. The circuit was based in the Fender 6G8 circuit end AB763. The PI tube is a 7025 as in 6G8.
Thanks a lot who try give-me an explanation!
I'm sending some pictures.
FAB
Old 19th November 2012, 10:12 PM   #7
nobody has some idea ???
Old 19th November 2012, 10:31 PM   #8
Wavebourn's Avatar
GU50 Prototypes
I have an idea. It is probably the result of some parasitic feedback, either capacitive between close input and output wires, or some common wire (so called ground) is soldered in the wrong place.
Old 19th November 2012, 10:40 PM   #9
Thanks Wavebourn, some day I will try fix the problem! But I would like to have some idea about what could cause the problem.
For the time being, I'm playing to have some fun!
Cheers FAB
Old 28th November 2012, 07:32 PM   #10
Alphy is offline Alphy
Hi Wavebourn, as I pm'd you months ago, still waiting for your 30+ Watts design with this endvalve .
GU50 PrototypesHide this!Advertise here!
Heil AMT Prototypes? Anyone ever seen anything like these units? matt28sr Planars & Exotics 18 30th August 2015 04:35 PM
3-Way Active Prototypes classdpwr Multi-Way 0 13th November 2011 06:18 PM
Prototypes... MikeB Solid State 23 20th December 2004 09:52 AM
FE107e prototypes done! 10" XLS next Dave Jones Full Range 8 26th May 2004 11:38 AM
Copyright ©1999-2017 diyAudio
