Instruments and Amps Everything that makes music, Especially including instrument amps.
fx loop on 5E3 clone
Old 21st December 2011, 07:23 PM   #1
famousmockingbird is offline famousmockingbird  United States
Default fx loop on 5E3 clone
I want to add an fx loop send and return so I can add a reverb processor. I was going to put the fx loop just before the phase inverter, I was just looking for some feedback from some members if I am doing this correct.
Here is the schematic:
Old 21st December 2011, 07:45 PM   #2
firechief is offline firechief  United States
firechief's Avatar
Are you adding gain to the overall pre-amp? The cathode follower looks right, but I wonder if you even need to add a tube section after the return. What is the max output voltage and impeadance of the reverb device?
"You can keep your insurance baby nothing is guaranteed" -Tom Petty
Old 21st December 2011, 08:12 PM   #3
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Load on the cathode follower is not so great. This is a better implementation:
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts. Bertrand Russell
Old 22nd December 2011, 01:03 AM   #4
jjman is offline jjman  United States
Does the 2nd stage clip? If not, a loop would have no benefit over using the effect in front. Unless the effect unit requires a line level input.
I'm using a lexicon in a (parallel) loop but it's after my 3rd stage which clips at higher preamp settings. I drive it via a voltage divider dropped to ground and boost it's return before the PI via 1/2 a 12ax7. Then recombine with the dry signal via a mixer pot.
Old 22nd December 2011, 01:32 PM   #5
Nigel Goodwin is offline Nigel Goodwin  England
What's with the 100K cathode resistors? - they look far too high.
Nigel Goodwin
Old 22nd December 2011, 09:51 PM   #6
Printer2 is offline Printer2  Canada
You just have to look at them a different way.
Old 23rd December 2011, 06:21 PM   #7
Input
Number of Channels: 2
Format: 1/4" unbalanced
Nominal Level: -10 dBV, adjustable to +4 dBv
Maximum Level: +10 dBV
Impedence: 1M
W/channel stereo, 500kW/channel mono
Output
Maximum Level: +17.5dBu
Nominal Level -20 dBV or +4dBu, front- panel adjustable
Output Impedance: 500 ohms
Here are the specs for the unit, and yes the 2nd stage will be clipping pretty hard and that is why I don't want the reverb before the gain stages.
I see from that weber schematic that the second triode in the 12au7 (the return) is another cathode follower. Which makes sense because I don't really want anything but a buffer for an fx loop. I found that schematic and thought maybe that the gain stage after the return might warm the digital processor up a little but not add too much gain.
Old 24th December 2011, 05:30 PM   #8
Presumably the signal to the PI would normally be stronger than what might come out the effects unit. Although your unit appears to have boosting potential on it’s output, using such could increase hiss. Mine does at higher output settings. So having a gain stage after the return is probably an appropriate option. I wouldn't know how to predict the numbers for a "transparent" result so I would use a pot on the grid of return's tube stage and use a scope to set it's output at parity with the signal strength that would go to the PI in the absence of the loop. Assuming preservation of the 5E3 clipping order/behavior is a goal. Then you could replace the pot with a divider or leave it somewhere on/in the amp in case you use a different unit. Like a delay or volume pedal.
fx loop on 5E3 cloneHide this!Advertise here!
LINE OUT 5e3 clone help please ArcticBreaze Instruments and Amps 14 17th December 2011 09:45 AM
Tube FX loop? escopunk Instruments and Amps 3 25th November 2011 08:36 AM
bandmaster ab763 fx loop hi_im_sean Instruments and Amps 2 17th November 2009 11:38 AM
FX Loop Mod. Noumenon Instruments and Amps 0 27th September 2007 06:12 PM
remote volume for FX loop? Keithm Instruments and Amps 3 18th February 2004 09:27 AM
Copyright ©1999-2017 diyAudio
