Instruments and Amps Everything that makes music, Especially including instrument amps.
Guitar preamp for LM3886
Old 3rd December 2011, 04:00 PM   #1
Mnvizb is offline Mnvizb  Lithuania
Default Guitar preamp for LM3886
Hello guys, I have just finished my LM3886 chipamp and since I am going to use this as guitar amp I will need a preamp stage. I thought about preamp using 12AX7, but I don't have money for it. Could you recommend me any simple preamp. I thought about this one Discrete FET Guitar Preamp
but I want at least variable gain (to get Overdrive). Thanks!
Old 3rd December 2011, 04:10 PM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
(to get Overdrive).
[/URL]
look up effect pedal curcuits
Old 3rd December 2011, 04:30 PM   #3
nigelb001 is offline nigelb001
No good. That's only got 3dB of gain, and do you only want clean, where's your overdrive coming from?
Tube preamp of some sort will give the best sound but otherwise something like the preamp section in this article may do it. I just googled and it was there!
Guitar amp project
Old 3rd December 2011, 06:27 PM   #4
indianajo is offline indianajo  United States
indianajo's Avatar
Tonepad.com has some naked PCB op amp projects. He sells PCB's, so buy your components locally. Don't use 741, use a pin compatible TL082 or 4558 or something.
I have found some tube 10W Bogan or David PA amps at the charity resale shop. The output transformers of these are garbage, but the LM3886 will replace that. The Bogen etc. power supply transformer and case are okay, All electrolytic caps will have to be replaced of course.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 3rd December 2011, 10:58 PM   #5
I have listened to some pretty impressive overdrive from a 1watt tube head
Old 3rd December 2011, 11:24 PM   #6
i2k92 is offline i2k92  Indonesia
The Tilman JFET preamp you mentioned will not get any overdrive/distortion.
I had Damage Control tube preamp years ago and IMHO the tubes are just gimmicks. From practical point of view I still prefer opamp based preamp like Sansamp GT2 and some other JFET based preamps. Go here for some good guitar preamps / simulators :
www.tonepad.com (sansamp GT2, one of the most famous preamp)
www.runoffgroove.com (JFET preamps derived from some famous guitar amps)
Old 4th December 2011, 03:26 AM   #7
Printer2 is offline Printer2  Canada
I personally like the Professor Tweed or the Eighteen.
Articles and Schematics
Old 4th December 2011, 08:28 AM   #8
I am currently looking at Professor Tweed, It is appealing to me that it reproduces that tweedy sound since I love blues, but i wonder If it can used as as preamp or just pedal. I mean when i would set his gain low for clean signal. Or does it need another preamp after it?
Old 4th December 2011, 08:38 AM   #9
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I'll second the GT2 clone, I built one to use 'till I get the funds to build my all valve fleawatt jobbie.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 4th December 2011, 09:11 PM   #10
I think it should work well without another preamp.
Guitar preamp for LM3886Hide this!Advertise here!
LM3886 Bass guitar amp docz Chip Amps 17 12th October 2010 11:02 AM
lm3886 building as guitar amp umut1001 Chip Amps 9 27th April 2008 08:06 PM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
lm3886 guitar amp? etec_noob Chip Amps 22 7th December 2007 05:14 AM
Problem with LM3886 guitar amp??? Minion Chip Amps 4 2nd November 2006 04:39 PM
Copyright ©1999-2017 diyAudio
