Instruments and Amps Everything that makes music, Especially including instrument amps.
Small and loud guitar amp?
Old 10th December 2011, 10:12 PM   #51
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by chris661 View Post
Tinitus, it's a 6FE200.
ah, ok, from their cheap range
Im looking at it
its a midrange driver, and never meant to be fullrange
I notice its with just 2mm Xmax, one way
and combined with a 120hz Fs, I would say not to be used below 300-500hz
unless you use a steep active high pass filter
and/or, live with much less SPL, and power handling
btw, of personal interest, how much did you pay fore this driver ?
Old 11th December 2011, 02:38 PM   #52
chris661 is offline chris661  United Kingdom
chris661's Avatar
Yeah, the limited Xmax is a problem for all pro 6" drivers.
I paid just over 30 for it.
I'll be using a second order crossover ~300Hz, sending the low passed output through a limiter (set earlier than the main limiter), recombining the signals, and then adding an overall limiter.
This ought to keep excursion sane, allowing it to go louder for the rest of the range.
The method described above is different from how ZT did their amplifier - they just put a steep filter at 200Hz. Seems to me that more could be had in the low end, even if only at practice/rehearsal levels.
Chris
Small and loud guitar amp?Hide this!Advertise here!
Need recommendations for DIY small guitar amp bst Instruments and Amps 37 3rd September 2011 04:13 PM
How many Watts for loud Class D Guitar amp? eem2am Music 8 30th June 2011 01:37 PM
hi, want to make tube amp + small loud speakers electrofan Introductions 5 17th April 2008 06:15 AM
Favorite Practice/small group guitar amp N9VOC Chip Amps 5 1st February 2008 01:42 AM
Help With Small Guitar Amp?? lgehrig4 Instruments and Amps 2 10th October 2005 06:10 PM
