Instruments and Amps Everything that makes music, Especially including instrument amps.
Humming from Amp with/without input
Old 19th October 2011, 10:53 AM   #11
Enzo is offline Enzo  United States
Oh, my apology, not a Vox AD30 at all, it is an Orange AD30.
I'd agree with Nigel then, in the humming channel, since there appears to be a level control after each stage, which ones will turn down the hum. That will localize the source.
Old 21st October 2011, 05:18 AM   #12
Mantua404 is offline Mantua404
ok I have actually said it the same from the beginning but I can see where my wording could confuse... The amp sounds and plays perfectly fine on all channels...
HOWEVER, a normal amp when the jack is unplugged should go dead silent... so if the amp is turned up full blast it should be silent if no input is plugged in.
On channel 2 it does go dead silent with no input which it always has and it should
HOWEVER, channel 1 has recently started humming as if an input was still plugged in even when there is no input.
I hope I worded that correctly this time. sorry for any confusion
Old 3rd June 2012, 12:57 PM   #13
Charly1 is offline Charly1  Australia
Hi Gents I got a different experience I build class A amp and when there is no input on input RC absolute no Hum.. As soon as input connected Hum start. Any Idea?
Humming from Amp with/without inputHide this!Advertise here!
help with my humming valve amp donny2pins Tubes / Valves 3 13th January 2010 07:39 PM
Guitar Pre amp humming problem ali_moinuddin Pass Labs 1 6th July 2009 04:31 PM
Arcam Delta 290 : Humming input selector. julian Solid State 6 7th April 2005 11:40 PM
Bridged OPA541 amp humming kinser Chip Amps 4 26th March 2005 10:14 PM
humming amp Pumuckel Pass Labs 10 26th February 2004 12:40 AM
