Instruments and Amps Everything that makes music, Especially including instrument amps.
60 watt 6l6 tube amp, too muddy...why?
Old 9th October 2011, 07:54 PM   #1
rotagen is offline rotagen  United States
Default 60 watt 6l6 tube amp, too muddy...why?
OK, I've got a couple of old Acoustic 60 watt guitar tube amps. Actually I find the tone very unique and warm, that's why I bought a backup.
But here's the deal, I'm always playing through pedals that boost the signal in a clean fashion. The tone is decent when I do this, but less "tubey" and more solid-state sounding. But the pedals (specifically my "treble booster" pedal) clean up the tone tremendously and get rid of a major problem: the bass while boomy is very very muddy and indistinct, not punchy at all...sloppy would be a good term.
When I go direct from guitar into amp this sloppy muddy bass is intolerable, even when I increase treble with my tone knobs. I've tried everything on amp and guitar but this never goes away.
I have replaced the tubes in the past but no dice, its still there.
I guess my big question is this: what do you think is the culprit here? Could it be that my transformers are low grade, too weak or something. Guess I just need to know some likely suspects in the circuit of the amp.
Tubes havent been changed in a few years, I ordered some new ones that should be an upgrade, but I'm skeptical they will remove the problem.
Thanks for any help I really want to "fix" this amp.
Old 9th October 2011, 09:00 PM   #2
kevinkr's Avatar
Per FORUM policy since this post relates to an acoustic instrument amplifier it belongs in I&A.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 9th October 2011, 09:02 PM   #3
kevinkr's Avatar
Additional information such as who made your amps, the specific model and an out of copyright (or hand redrawn) schematic would really help a lot.
Have the power supply capacitors or any other components in these presumably old amps been replaced?
The fact that your pedals make it sound better point to a possible interaction between the guitar and the input electronics in these amps, again having a schematic or something more to go on would help..
Old 9th October 2011, 09:08 PM   #4
I do have the schematic on a cd somewhere, will post soon after band practice, thanks for those ideas. No caps have been replaced, it is an Acoustic tube-60 Collaboration Series made in 1987 or thereabouts, thanks again.
Could a weak output transformer cause this problem?
Old 9th October 2011, 09:09 PM   #5
Just a quick note "Acoustic" is the Brand name , it is an electric guitar amp. thanks.
Old 9th October 2011, 10:13 PM   #6
kevinkr's Avatar
Very unlikely to be an output transformer, I suspect a combination of design and old components - particularly the electrolytic capacitors in the power supply which are way overdue for replacement.
Old 9th October 2011, 11:17 PM   #7
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Kevin is your tube amp master
I won't mess with him
but that your pedals change the 'issue', and sounds better
it could indicate impedance problems
I wonder if some owner before you lowered input impedance
that you got a couple, maybe tells that they might have been used fore hifi/stereo
Old 10th October 2011, 02:27 AM   #8
Keriwena is offline Keriwena  United States
Note that he's using treble boost pedals to overcome boomy bass. (As I recall, Acoustic was known for bass amps.)
Have you tried a different speaker?
Old 10th October 2011, 05:17 PM   #9
razorrick1293 is offline razorrick1293  United Kingdom
sounds like a power supply problem, is it valve or diopde rectified? switching to diode rectification might help and as kevin said, the caps probably could do with replacement. as for impedance problems, i doubt this is the case, although it can contribute, i cant see it making a significant difference. also, if any bypass caps are electrolytic then it probably wouldnt be a bad idea replacing them either, and if theyre relatively big, making them slightly smaller wont hurt.
Old 10th October 2011, 05:54 PM   #10
Printer2 is offline Printer2  Canada
It could be the input impedance to the amp being too sucking highs off the guitar, power capacitors being old, cathode bias amp with small cap, a whole host of things. Just guessing without a schematic.
60 watt 6l6 tube amp, too muddy...why?Hide this!Advertise here!
my 250 watt tube amp can be a 500 watt tube amp for less than 2 bucks plus tubes speakerfritz Tubes / Valves 17 24th October 2013 11:50 PM
WESTREX 60 WATT AMP payitforwardeddie Tubes / Valves 13 25th July 2011 03:29 PM
6l6 tube amp troubleshooring progress speakerfritz Tubes / Valves 6 30th September 2010 10:33 PM
Scratchy clicky noise coming from homemade 6L6 tube amp Jim5150 Tubes / Valves 4 25th June 2009 10:53 AM
