Switchable Hi-Z input impedance, how ? Switchable Hi-Z input impedance, how ? - Page 71 - diyAudio
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 14th December 2013, 09:01 AM   #701
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
decided I wanted a new front
sometimes we know very little, and sometimes we know too much
Old 15th December 2013, 06:22 PM   #702
must have handles
Old 19th December 2013, 06:06 PM   #703
Originally Posted by tinitus View Post
now testing this 'tone curcuit' on different basses
this is simpler, and better
cleaner, and tighter
and somehow results in better harmonics
also, instrument is easier to tune
tested on two basses, and result is more or less the same
it is 100% clear now that a tone control also affects tuning
and could be quite a lot really, and even involve the bridge
so, if anyone have a bass that is 'difficult' to tune, it might very well be caused by the tone control
Old 21st December 2013, 09:22 PM   #704
I don't know why, but it appears grounding the tone pot metal housing induces annoying hiss noise
and increasing string noise as well
also experienced this with other basses
Old 24th December 2013, 09:40 AM   #705
more work on my amp front plate
Old 6th January 2014, 04:36 PM   #706
found a place for guitar input buffer
+/-15V is available on input board
and there is enough space for exstra gain by adding jfet input
Old 9th January 2014, 05:03 PM   #707
and this is the final result of the tests
best allround tone of all I have tried yet
at least for my speaker it is
typically I use caps from 15n to 33n
series resistor varies from 1k to 3k
parallel resistor on pot is typically around 22k
small variations depends on each instrument
Old 9th January 2014, 10:19 PM   #708
woodwork finished
Old 18th January 2014, 07:32 AM   #709
and got the toggle switch I needed to drill holes
Old 20th January 2014, 09:48 AM   #710
front finished, more or less
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright ©1999-2017 diyAudio
