Instruments and Amps Everything that makes music, Especially including instrument amps.
Switchable Hi-Z input impedance, how ?
Old 3rd September 2013, 10:19 PM   #661
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
the mail man delivered a very interesting card box today
sometimes we know very little, and sometimes we know too much
Old 4th September 2013, 07:15 AM   #662
Old 4th September 2013, 08:57 PM   #663
changed the shape a bit
(removing all router roundings)
and forgot to mention
its a kit and came with all parts needed
thinking about how finish/color
but not sure yet
Old 5th September 2013, 08:46 PM   #664
and just couldn't resist to replace the original control board
Old 8th September 2013, 07:49 PM   #665
cut off a small bit of the pickguard
and since all holes are pre drilled ...
the small hole is now a small dot instead
Old 11th September 2013, 08:12 AM   #666
the neck joint
predrilled body holes are ok, and matches the mounting plate
but the holes in the neck are far off
only one hole is where it should be
I can plug the holes, and drill new ones
or consider thread inserts
fortunately the neck joint was way too tight
which means at least that is a good fit now
Old 12th September 2013, 10:53 AM   #667
bridge support construction
Old 13th September 2013, 11:30 AM   #668
looks like the bridge moved slightly left towards E-string, and a bit forward
Old 13th September 2013, 12:28 PM   #669
shanx is offline shanx  Canada
Hi Tin,
Before you go any further I suggest to check alignment of bridge/neck and also the neck angle. Set it up using strings of a gauge you normally use and verify it can be adjusted to the action you want. Easier to make changes now than later. I am surprised the tailpiece holes were that far off, unless the neck pocket wasn't routed properly (the neck holes seemed to be misaligned to the body, from your picture)
Old 13th September 2013, 08:53 PM   #670
Originally Posted by shanx View Post
Hi Tin,
I did that before this, using a metal band
but small adjustments are still possible
I moved the bridge forward because I always seem to land at the end of the screws
and my 'scale'/free string length varies from close to 860 to 865(mm)
the sidewards move of bridge
Im trying place the string load so that it pulls the neck towards left side of neck joint where the body neck support is
or if you like ... avoiding the neck is being pulled towards G-string where there is no body support, and only the screw to hold it
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright ©1999-2017 diyAudio
