Switchable Hi-Z input impedance, how ? Switchable Hi-Z input impedance, how ? - Page 51 - diyAudio
Instruments and Amps Everything that makes music, Especially including instrument amps.
Old 18th April 2013, 10:24 AM   #501
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
att gain control pot mounted directly on jfet output
Old 18th April 2013, 12:20 PM   #502
shanx is offline shanx  Canada
Can try it like that, in that position the 2 additional resistors should be relatively high value. Then I would suggest trying to move the attenuator to after 4 uf at the output side. Maybe a 10K or 50 K pot.. the output impedance is related to the emitter resistance in parallel with the pot. So it is still low. Are you getting about a volt of signal swing at the jfet output? You will probably want all of that going into the BJT buffer , instead of attenuating it. Will keep noise lower. My humble suggestions only..keep playing around with it and hope your having fun!!
Old 18th April 2013, 12:54 PM   #503
Originally Posted by shanx View Post
.... output impedance is related to the emitter resistance in parallel with the pot. So it is still low.
ahhh, ofcourse....simple emitter follower
I understand you better now
good info
thanks
Old 18th April 2013, 03:37 PM   #504
Tin,
you should add a DC blocking cap between the first stage output and the input to the attenuator.
Do not pass DC through the pot.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th April 2013, 04:15 PM   #505
sounds like the pot is in the wrong position, with the simple bjt emitter follower
and since the simple emitter follower will work well having a pot on its output, like shanx suggested, that is what Im going to try
File Type: jpg bass pre jfet BC547 buffer output pot.jpg (27.1 KB, 23 views)
Old 18th April 2013, 04:37 PM   #506
The arrangement of the buffer after the pot is correct.
Now that you have a Cap between the two, you can set the bias properly.
Just stop DC flowing through the pot.
regards Andrew T.
Old 18th April 2013, 05:15 PM   #507
att pot on input instead
File Type: jpg bass pre jfet BC547 buffer pot first.jpg (28.8 KB, 22 views)
Old 18th April 2013, 07:04 PM   #508
Hi Tinitus, if your bass has a volume control (which I assume you do) you don't need the pot at the input. Adding another attenuator (parallel with you bass volume control) at input will defeat the purpose of the Hi Z input. Your previous schem will do what you need and you can drive your circuitry down the line to a level that suits them.
Old 18th April 2013, 08:37 PM   #509
ahh....confusing, I know
right now I have a Hi Z preamp driving this BJT buffer
and its got two jfet gain stages, with att/volume control
and its a single input jfet, split into two channels
so basicly it would look like this
File Type: jpg bass pre jfet BC547 buffer pot first.jpg (63.2 KB, 20 views)
Old 18th April 2013, 08:41 PM   #510
but maybe I dont need the BJT buffer at all
it was just to see if it would work
and I read its good driver with low output impedance
I guess ideally, the Hi Z jfet should be integrated on-board with the instrument
and in such case, the preamp with att at input would be fine
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright ©1999-2017 diyAudio
