Instruments and Amps Everything that makes music, Especially including instrument amps.
Switchable Hi-Z input impedance, how ?
Old 29th October 2012, 02:50 PM   #391
juma is offline juma  Germany
juma's Avatar
Standard Q&A:
How much gain do you need ?
What's the input signal level?
What power supply you have?
What's the load ?
Source Follower can't give you voltage gain - to accomplish that the parts must be mixed together differently...
Old 29th October 2012, 05:39 PM   #392
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
ah, juma, glad you are still around
well, I thought now that Im going to use +/-12V like you suggested for the j310/CCS buffer.....
but I have regulated supply, and 2x 18Vac trafo, so it could be almost anything
not sure I have all the answers, yet
the plan was to replace the k170 in simple boz with the j310
I think you mentioned 12db
and with its lower gain I could have more gain stages, instead of buffers
and only have buffer at output
might be 3 gain stages
one at input, another at tone control, and with another one around the att before output buffer
and then the the j310/CCS buffer output
reposting old not yet revised layout, just in case
Old 29th October 2012, 06:49 PM   #393
here revised with your j310/CCS buffer
but still with jboz gain stages
Old 30th October 2012, 12:18 AM   #394
btw, also thinking about putting in 'optional' 12db active low pass and high pass xo
Old 30th October 2012, 01:05 PM   #395
juma's Avatar
Simple 12dB gain stage with J310 would look like this. J310 is quite different from 2sk170 so it has to be configured differently for this task (12dB gain and about 5V of clean swing). Id is low (about 1mA), Zout is high, but it works nice and buffer will be used at its output anyway...
For 9dB gain, change R2 to 3k6, it will also make the gain stage more linear.
Old 30th October 2012, 04:38 PM   #396
nice, thanks
now with +30V
but I suppose thats the price to pay for good voltage sving
will see if I can find a trafo for it
would it work with 12db active xo
I have tried to mate a 12db xo with the j310/CCS buffer, but not sure it will work
apart from some tube buffered curcuits, LC audio's xo is the only discretely built xo I could find
but he connects the feedback loop to ground instead
Old 30th October 2012, 10:03 PM   #397
juma's Avatar
It's OK.
You don't need two resistors to ground (HP section).
Look here:
Linkwitz-Riley Electronic Crossover
Old 30th October 2012, 10:11 PM   #398
ah, I see, the resistor is 80K for 200hz
great
this will be fun
better begin to order parts
Old 31st October 2012, 09:59 AM   #399
gosh, those J310 SMD are small...2.9 x 1.3 x 0.9mm
with SMD resitors and caps, a high or low pass wouldn't take up much space, almost like nothing
wonder if there would be a double BC547 SMD
ehh, that would be a junction type, I guess
juma, any ideas/suggestions ? or am I too crazy now ?
would that be like BC847
http://docs-europe.electrocomponents...6b80dabb08.pdf
Old 31st October 2012, 10:21 PM   #400
thinking about mounting buffer and active xo on small boards with a dil socket adapter
would make it easy to change xo
or if no active is wanted, just mount a buffer board without xo
Originally Posted by tinitus View Post
now with +30V
for the J310 gain stages
I have the 0/18Vac trafo Im using now for the simple jboz
maybe I could try with a voltage doubler
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 01:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 10:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 11:24 PM
Input impedance nhuwar Tubes / Valves 24 24th July 2007 12:11 AM
Input pot and input impedance Bricolo Parts 1 19th March 2003 02:59 PM
Copyright ©1999-2017 diyAudio
