Instruments and Amps Everything that makes music, Especially including instrument amps.
Switchable Hi-Z input impedance, how ?
Old 12th October 2012, 03:17 PM   #371
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
found a nice sized midi box
might be good for this
but needs some 'reworking'
Old 13th October 2012, 05:06 AM   #372
Originally Posted by juma View Post
And if you want a single ended buffer with J310 (like B1) you'll have to put up with Zout of few hundreds Ohms or to use coupling cap.
ah, I see what mean
if no cap, there would need to be resistors to adjust the dc, and thus higher zout
could a j310 output buffer look something like in this ?
Old 13th October 2012, 06:31 AM   #373
Originally Posted by tinitus View Post
need to get hold of some veroboard, and more components
to-92 j310, says obsolete but available as surface mount, at least but 2N5459 seems available, and widely used
and seems I can find 5457/58, and a 5952, and maybe 2sk246
need to keep it straight and on track now...have to be a lower gain device like the j310
Old 13th October 2012, 10:55 AM   #374
juma is offline juma  Germany
juma's Avatar
Yes it could, but since you have a lot of BC547 you can use them as CCS (see attached sch.). If you plan to use SMD J310 don't go over +/-12V PS voltage and to lower the Pd you can change R4 from 68R to 100R. Expect Zout in range of 100 to 150R (R6 included).
Old 13th October 2012, 11:10 AM   #375
hey, thats the one, I like it, simple and very cool looking buffer
thanks juma
any alternatives to the j310 ?
(and not to forget, I still have 2sk170)
and btw, also have some 2sj313/2sk2013
but again, different stuff, I know
oh, and it appears all my BC547B, are...B types, Motorola(736ZF)
Old 13th October 2012, 11:52 AM   #376
juma's Avatar
... any alternatives to the j310 ?
(and not to forget, I still have 2sk170)...
BF245C can be used - it's cheap and abundant, but with it you can expect a bit higher Zout (200 - 250R).
You better save k170 for hi-fi projects but if you insist to use them this way, set the current through BC547 CCS to about 80-90% of Idss (by means of R4 - higher resistance => less current)
...oh, and it appears all my BC547B, are...B types, Motorola(736ZF)
It doesn't change anything important here...
Old 13th October 2012, 01:43 PM   #377
j310 with CCS looks just perfect for me, thanks
I better ask you to look at the specsheet, to be absolutely certain its ok
http://docs-europe.electrocomponents...6b80a9d07e.pdf
Old 13th October 2012, 05:12 PM   #378
juma's Avatar
What do you mean by "absolutely certain it's ok" - what's troubling you ?
Old 13th October 2012, 05:57 PM   #379
oh, sorry, I just want to make sure that the SMD in the link(spec sheet) really is a j310 and the same as the TO-92 j301
Old 13th October 2012, 06:42 PM   #380
juma's Avatar
Some characteristics are the same, some are not...
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright ©1999-2017 diyAudio
