Instruments and Amps Everything that makes music, Especially including instrument amps.
Switchable Hi-Z input impedance, how ?
Old 2nd August 2012, 11:11 PM   #251
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
no, not yet
Old 3rd August 2012, 07:17 AM   #252
will try a different approach
decided to dump the tube direct out
instead I will try to incorporate the tone bypass into the same signal switch
but could present the same problem
not sure yet
Old 3rd August 2012, 10:45 PM   #253
pretty certain this simpler switching layout will work ok
its now only tube bypass, thats all
true bypass, cutting both input and output, ofcourse
the 'reward' of making it simpler would be more switch options left to do a bigger LEDs lightshow might be fun
not sure I will need a tone bypass at all
Old 3rd August 2012, 11:21 PM   #254
actually, for this one, a simpler ON/OFF/ON switch might be even better, leaving OFF position for muting
but there is still one option I will look at
with a second output plug on back panel, it might be very simple to do a 'direct out' from input buffer
or a more advanced version of this could be used for effects loop
but that option might still need a secondary effect loop switch on back panel
Old 4th August 2012, 07:34 AM   #255
now looking at input options
might use the same 4pole ON-ON-ON switch
not sure yet how to
Old 4th August 2012, 09:02 AM   #256
could look like this, with completely seperate channels
might be 'convenient' for PA/stereo
File Type: png bass pre layout 140 sep input switch.png (60.7 KB, 27 views)
Old 5th August 2012, 07:46 AM   #257
oh no, not that again
it will only give a headacke
one input only
and a 'simple' send and return effect loop, switched
File Type: png bass pre layout 150 sep input switch.png (57.2 KB, 5 views)
Old 6th August 2012, 07:37 AM   #258
no, no, no
I will not have effects option
connect other 'strange' curcuits, and this whole project would become more or less pointless
would rather 'waste time'on adding that exstra tube direct out switch I previously gave up on
a 'fast switch' for tuner have been considered
but I reckon most tuners are switched on by the instrument jack/plug connection
means it would be permanently 'on', even at preamp power off
would make battery operation completely pointless
and a tuner especially is the only device I would ever use on battery supply
Old 6th August 2012, 09:53 AM   #259
hmm, about the tuner
mighty actually be very practical to have a paralel output, just for tuning
wont even need a switch or anything
just a second plug in paralel with instrument high-z input
makes sense
instrument jack wouldnt have to be pulled
just plug in the tuner to the second plug
tuning while playing would be easy
in light of that, maybe think twice about where to place the muting cut
both audible and silent tuning should be possible
Old 7th August 2012, 09:30 AM   #260
ok, back to .... well
with the added input switch, I will once again try to look at handling each channel seperately
meaning it will be possible to connect different effects to each channel seperately
and each channel will have its own bypass option
muting is a multiple hybrid solution
it either 'kills' both channels
or its optional signal out
for a tuner, or...
well, dont expect too much
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
