Instruments and Amps Everything that makes music, Especially including instrument amps.
Switchable Hi-Z input impedance, how ?
Old 31st July 2012, 07:07 PM   #241
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
for a start, just to get an idea of how this switch works
so far only half of it used
and not yet right either
Old 1st August 2012, 08:58 AM   #242
wow, I think switch works
position 1 and 2, all curcuits active
position 3, tube bypass, direct to tone curcuit with tube output muted
tone curcuit can be bypassed fast easy in all positions, having its own tone defeat switch
pole 11 does LED duty
and pole 5 is still free
well, might have nice to switch output
could be a tube direct out option
but havent figured that out yet
Old 1st August 2012, 09:09 AM   #243
hey, pole 5 on output might actually do that
Old 1st August 2012, 11:22 AM   #244
yep, not 100% sure yet, but this might work
it should give 3 switch options, one with tube direct out, one with curcuits active, and one with tube bypass
shoot, small error on tube direct out
though, tone output is cut, its input is still connected tube out
not sure thats good
Old 1st August 2012, 11:45 PM   #245
looks like I should let that 4P3T switch take care of signal in and out only, and not do the tube bypass
the added bonus is still tube out direct option, which actually wasnt planned
tube bypass will still possible with seperate switch, no problem
Old 2nd August 2012, 08:11 PM   #246
.... and not do the tube bypass
yuoiee looks like it is possible
I think it works
Old 2nd August 2012, 08:24 PM   #247
aqhh, nope, but very close missed the connection from tube out to tone curcuit but its there, somewhere
Old 2nd August 2012, 08:26 PM   #248
shanx is offline shanx  Canada
Good stuff! I will take your word for it that it is working..I haven't checked it. Are the circuit boards finished up?
Old 2nd August 2012, 09:11 PM   #249
no, need parts
desided a while back I would want mains power outlet from backpanel, using PowerCon's....and they were on back order
now they have them, and its time to order, but Im busy now
but a friend delivered my 'smoked' poly front plate today
Im running out of 'excuses' now
Old 2nd August 2012, 10:55 PM   #250
thanx, almost sure this one will work
need to check it later, but it looks right
now I can order parts
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
