Instruments and Amps Everything that makes music, Especially including instrument amps.
Switchable Hi-Z input impedance, how ?
Old 28th July 2012, 04:18 PM   #231
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
small trafo for the LEDs have now found a new home
and btw, it will have its own mains fuse, so that it dont take out the whole amp in case of errors
which is also part of my point with having both solid state and tube curcuit
should a tube fail, or in need of being replaced, it will still be a fuctional preamp
still need parts for the regulated +/-20V
Old 29th July 2012, 09:29 AM   #232
trying to rethink my curcuit/function layout
first, the tone control
I suppose it would optimally have a buffer on both input and output
despite the fact thats it means adding further curcuits
and that its best not to place any att in between
buffers will be placed together with the control knobs
all mounted on a small bord behind the front plate
Old 29th July 2012, 11:07 AM   #233
and, thinking about a rotary switch after the first gain stage, with a direct out option
Old 29th July 2012, 11:19 AM   #234
problems
Old 29th July 2012, 01:13 PM   #235
and a possible new front for the changed layout
good thing Im slow, sometimes
Old 29th July 2012, 11:33 PM   #236
3P4T rotary switch
could be I have solved it now
pos 1 is first gain stage direct to output
pos 2 involves the tone control (toggle bypass for fast tone defeat)
pos 3 involves tube stage output
pos 4 input direct to tube stage output
Old 30th July 2012, 06:42 AM   #237
Originally Posted by tinitus View Post
3P4T rotary switch
shoot, no, not quite so simple
maybe better go back to the one with all bypass toggle switches
or a combination
Old 30th July 2012, 03:06 PM   #238
have found a 4PDT toggle switch with ON/ON/ON switching that might give what I want
Old 31st July 2012, 12:08 AM   #239
man, thats a tricky one
its a 4P ON/ON/ON
but with jumpers made a DP3T
read that jumpers are external and may be cut to make it 4PDT
I do need at least 3P because of the LEDs
but maybe the last 4th pole could work with leaving one of the jumpers
which would make it a mixed 4PDT/3P3T hybrid, or whatever aint switches just a lot of fun
Old 31st July 2012, 08:27 AM   #240
and the 4P switching with both jumpers cut
it gives 3 options
and able to 'create' complicated connections
or in other words, it can do signal in/out switching and bypass at the same time
and still have a free pole for LEDs
now I only need to figure out what is the reality
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright ©1999-2017 diyAudio
