Instruments and Amps Everything that makes music, Especially including instrument amps.
Switchable Hi-Z input impedance, how ?
Old 2nd June 2012, 07:56 AM   #141
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
found RCA tone control manual
and a Crowhurst article
looks like even I can do that
btw, consider its a 2channel/stereo
using one channel for bass, and one channel for mid/top
enables the two channels to be configured differently
like using the trick with a small bypass cap on cathode resistor, to achieve a little more high frequency gain
and having seperate attenuator for each channel further enhances sound balance control
Old 6th June 2012, 10:18 PM   #142
trying to draw curcuit, with EQ
not sure why the cathodes are bootstrapped
but seen that elsewhere
hmm, maybe only output tube should be bootstrapped
Old 7th June 2012, 11:53 AM   #143
I find it exstremely funny to read a text bit like below
Old 7th June 2012, 08:27 PM   #144
ah, ok
by bootstrapping, the input/gain tube would achieve a bit more gain
guitar amp builders say it gives more 'grunt'
well, no real need for that here
bootstrapping the cathode output tube gives higher impedance load
and that might be of advantage, considering the EQ curcuit
well, I dont know this, but it seems logical
hope its beginning to look better
Old 8th June 2012, 08:11 AM   #145
ahh, managed to make the desired drill/router bit for doing solder pads
have been on the to do list for some time
needs a bit 'refinement', but seems to work ok
means I can get on with the solid state output (BA-3)
Old 8th June 2012, 09:45 AM   #146
needs a bit 'refinement'........
works better, smoother and much faster now
I think it will be a good tool
Old 8th June 2012, 10:24 AM   #147
and this is the way I plan to use it
seems like I will have to do some cuts for soldering directly to the ground plane, or else it takes too much heat
hmm, solder pads appears to be a bit big for some smaller components like multiturn pots with smaller legs
might have to use bigger pots
or try to build a smaller tool
well, I might take the challenge
Old 8th June 2012, 10:52 AM   #148
its close, but looks like that will work too
Old 8th June 2012, 12:14 PM   #149
Nigel Goodwin is offline Nigel Goodwin  England
Why not just build it on plain matrix board?.
Nigel Goodwin
Old 8th June 2012, 01:38 PM   #150
I dont have any
only ordinary boards
old pieces, bought long time ago
why waste them
anyway, you dont find it good to have a 'free' ground plane ?
but ofcourse you are right, matrix board would be easier
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
