Instruments and Amps Everything that makes music, Especially including instrument amps.
Switchable Hi-Z input impedance, how ?
Old 29th April 2012, 03:32 PM   #111
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Printer2 View Post
Do you have any bass sound you are shooting for?
clean
and natural, whatever that means
the only distortion I will accept is what makes it sound in the direction of acoustic bass
actually, right now, the only pre I have between my passive bass and power amp is a simple Bass EQ pedal switch thing
works ok
it even works in bypass mode
but it tells me that my future preamp build may be all I will ever need
that feels good, somehow
but if this speaker goes active, I will still have some means of controlling the sound
Old 29th April 2012, 04:26 PM   #112
Printer2 is offline Printer2  Canada
I guess we dropped the distortion requirement along the way and I missed that. Should be relatively straight forward then.
Old 29th April 2012, 04:56 PM   #113
I hope so
well, may not be that simple, it seems
part of my problem right now is distortion
its fine at low SPL
but I loose the clean sound when I play just moderately louder than low
Old 29th April 2012, 05:36 PM   #114
Originally Posted by tinitus View Post
I hope so
its fine at low SPL
Compression.
Old 29th April 2012, 08:08 PM   #115
Compression.
on its way
Old 8th May 2012, 07:31 AM   #116
Compression.
wow, it works
hard to imagine playing without it now
like night and day, really
Old 10th May 2012, 05:07 AM   #117
funny, I just now found that the compressor has a high/low gain switch, for active/passive pickups
wonder what gain will be optimal for my tube pre
Old 10th May 2012, 04:49 PM   #118
ordered a few 6n6p
and then decided, why not use 6n1p in front of it
so, a few of them ordered as well
Old 11th May 2012, 08:02 PM   #119
Old 12th May 2012, 08:45 PM   #120
got the plywood itch
had some 6mm plywood leftovers
and glued them together, into 12mm pieces
and hopefully the end result will be a nice box
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
