Instruments and Amps Everything that makes music, Especially including instrument amps.
Switchable Hi-Z input impedance, how ?
Old 28th March 2012, 02:24 PM   #101
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
no
well, maybe the higher gain of ecc83 would be to have
my cheapskate effects are a bit noisy, and thickens the lower mids at higher level
and that is exactly what Im trying to avoid
so it seems Im still far from 'my sound'
I have ordered the new Palmer Deepressor pedal
but on backorder
Old 29th March 2012, 01:41 PM   #102
hmm, 7025(ecc83) input tube with ecc88(6DJ8) output(buffer)
need to decide on trafo voltage
Old 11th April 2012, 09:16 PM   #103
ok, I got the Aikido mono solo boards
it will be my instrument input
and I expect my two channel Burning BA-3 (NelsonPass) will look like this
this will be my output gain/buffer
now I need some power supply parts
Old 13th April 2012, 05:48 PM   #104
going to order trafo
planned voltages
0-195-215-235 (100mA)
maybe 100mA is a bit high for a preamp, I dont know ?
6.6-3.3-CT-3.3-6.6 (1.5A)
0-18 / 0-18 (1.5A)
and maybe I would like exstra voltages for effects, 0-9-12-15V
maybe getting a bit complicated in one trafo
Old 13th April 2012, 09:07 PM   #105
BA-3, a full ground plane seems to make sense here
and where a hot connection is needed, I will just route away with engraving bit
a hybrid combination of hard wire and hole mount
would be really nice to have a small tool to route around the holes
Old 14th April 2012, 06:19 AM   #106
old thread, but might be worth reading
12AU7 vs 12BH7 vs 6CG7
Old 16th April 2012, 11:08 AM   #107
trafo ordered from Toroidy
0-195-215-235V (110-120mA)
6.6-3.3-CT-3.3-6.6 (1A/2A)
2x 18V (2A)
special audio quality
Old 26th April 2012, 08:43 AM   #108
possible preamp 'configuration'
Old 29th April 2012, 07:21 AM   #109
had a lucky day
guess I will have to build my own 'power brick' now
Switchable Hi-Z input impedance, how ?Hide this!Advertise here!
Switchable balanced / unbalanced input buffer nigeljking Analog Line Level 4 12th September 2011 12:03 PM
How to design input stage with specific input impedance/pot value mahleriana Tubes / Valves 0 16th November 2009 09:37 PM
Input Impedance Bengali Analog Line Level 7 15th August 2007 10:24 PM
Input impedance nhuwar Tubes / Valves 24 23rd July 2007 11:11 PM
Input pot and input impedance Bricolo Parts 1 19th March 2003 01:59 PM
Copyright ©1999-2017 diyAudio
