Instruments and Amps Everything that makes music, Especially including instrument amps.
Guitar amp loadline - check my work?
Old 4th September 2011, 08:40 PM   #1
taj is offline taj  Canada
taj's Avatar
Default Guitar amp loadline - check my work?
I've been scratching my head over this recently. It's my first try at creating a loadline, so any advice is welcome. The goal is to use a single-ended 6DQ6B final. Linearity is not a concern, though I want more H2 than H3 (i.e. harmonics descending as order increases). No other restrictions.
Here's what I came up with. Do my calculations make sense? The datasheet only shows curves for G2=150V so I've graphically scaled them up to 175V by referencing the G1=0v for G2 curves plot.
The tentative plan is to use a voltage doubling power supply in order to provide an easy G2 supply tap.
..Todd
Old 5th September 2011, 01:57 AM   #2
Michael Koster is offline Michael Koster  United States
Michael Koster's Avatar
No way will you get 9.2W Po with < 18W dissipation. Something is wrong with the way you derived your load line. The slope doesn't correspond to 5K load. Power should be calculated by multiplying RMS voltage swing by RMS current swing. I don't know how you got .045 for current. You can also use Vrms ^2 / Zload but you have to get the load line right first.
Old 5th September 2011, 02:35 AM   #3
taj's Avatar
Back to the drawing board. Thanks Michael. I'll get it figured out one day.
Old 5th September 2011, 06:10 AM   #4
taj's Avatar
Okay, I think this is better. The load is 10k (corresponds to 50mA over 500V) and the power calculates to 4.2W which shouldn't raise any eyebrows.
Any advice? (he says, ducking...)
..Todd
Guitar amp loadline - check my work?Hide this!Advertise here!
Will this work? Please check rinox Power Supplies 13 1st February 2010 03:54 PM
Please check my work :) athos56 Tubes / Valves 11 17th August 2008 08:05 AM
please check my work gary h Tubes / Valves 10 10th August 2008 11:52 PM
Guitar Amp buzzes off of power inverter, will this filter work? silentblackhat Instruments and Amps 14 10th November 2006 12:39 AM
ELF (Check my work, please) fortyquid Subwoofers 4 1st October 2003 08:48 PM
